11-02-2017, 06:00 PM | #1 |
Ecs l99 / Meth question
Recently got the kit installed along with a snow performance kit, car runs great , but cold starts always result in a crank with trouble turning over, have replaced the battery , as well as had the tuner look at the tune , any ideas what could be causing this ?
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
11-03-2017, 07:22 AM | #2 |
Drives: 2014 SS 1LE Join Date: Apr 2014
My guess is the tune.
11-03-2017, 07:28 AM | #3 |
Yea I’m thinking the same gotta do some data logs , just wanted to see if any of you guys experienced this and what u did to fix it
11-09-2017, 04:23 AM | #4 |
When I was supercharged I had a similar issue. Turned out my meth nozzle was leaking just a little bit into the intake. So on cold starts my car would be to rich to start right away. I also had a snow kit.
https://www.instagram.com/whoopa_ss/ |
11-10-2017, 09:29 AM | #5 | ||
Be glad to take a look at it for you. Ted.
www.jannettyracing.com
11-10-2017, 04:14 PM | #6 |
Drives: 2018 ZL1 A10 Join Date: Mar 2013
Had same issue. Meth was installed without the check valve. Installed one and no more hard starts.
Work in progress
12-09-2017, 09:35 PM | #7 |
Bump
12-10-2017, 07:58 PM | #8 | |
What did you do to fix it?
