08-20-2019, 01:56 PM | #15 |
Drives: like an old lady Join Date: Jun 2012
what kind of fuel system is needed to support 800 hp on e85? what oil pump are you guys using? when will these cyl heads be on market, sold separately?
2016+ camaro: everyone’s first car
08-20-2019, 02:31 PM | #16 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
08-20-2019, 02:31 PM | #17 | |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
-Katech HCS/HCP oil pump -The cylinder heads are now available and sold seperately, here: https://store.katechengines.com/kate...eads-p854.aspx |
08-20-2019, 03:20 PM | #18 | |
Drives: Black Join Date: Jan 2017
Yeah maybe with a good driver, slicks, weight reduction, stall, etc. Mclaren does it on street tires out of the box and traps like 145mph. 720s would for sure be a little faster than a c8 vette with this motor with the same tires, driver, etc etc etc. |
08-20-2019, 03:36 PM | #19 |
Drives: SS 6 speed of course Join Date: Jan 2016
Me thinks you lack the confidence in the Force.... young padawan... First you must take down the 650 then as your skills improve you can become a master.
https://www.roadandtrack.com/new-car...ive-road-test/ Once you start throwing that kind of money around, things like lihium battery, carbon fiber rims, a dual inject titanium rod 427 with twin turbo are all within reach and it is not like the C8 is that far behind even in base-model form. McLaren is going put a billion dollars into doubling production to 6500 units a year (going from memory now). Maybe they can do it??? dunno as I'm a CHEVY driver, don't rub noses with the elite. Vette production is 30K to 40K and IMO will rise from there. To me it is American Graffiti. how has enough money to take down the Japanese guys in the Shelby Road Cobra.... Clearly with off the shelf stuff the LT powered C8 is going to be a force of nature, and once some serious cash gets into it, yea 1000+ HP is going to be the new normal for the average C8 Vette owner...
08-20-2019, 04:00 PM | #20 |
Drives: '17 1ss Join Date: Jun 2017
Can you guys just sell porters castings no cnc work?
08-20-2019, 04:14 PM | #21 | |
Drives: 2018 Audi TT RS Join Date: Jan 2014
I'm scouring the field at the moment to see what's out there and if I think it's worth keeping the car. I've seen your guys' previous 427 builds and prices. I like the engine but the cost is always a shock. With this engine, you have my attention again but, I won't run the Holley intake, largely due to the hoods required to clear it. Also, how much will the headers from Kooks cost that are required for these heads? It may just boil down to cost and viability, as to what choice I end up making.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
08-20-2019, 04:46 PM | #22 | |
yes depending on your stipulations things can change. but now we are going to give stipulations to a 300,000 dolar car vs a Camaro or a 70k vette? all you said originally was that you cant beat a 720s with this motor. not even close to true. last I seen 720s record on a tire was 9.7. in good air. for 3100 lbs its not making the hp you claim. looks like its making 750 range. Brandon hills 6th gen ran 9.6 making 750hp verified on an engine dyno at 3400 lbs a 3300 lb c8 with this 800hp motor setup to hook at the track would beat a 720s on a tire. in my opinion. a 3400 lb 6gen with 50 less hp has been 9.6. you wont be running this motor without a stall converter in an auto either. its going to be way out in front of the 720 both hooking. |
08-20-2019, 05:40 PM | #23 | |
I was in the same boat not too long ago, It was between keeping my 5th gen or upgrading to a 6th. I am now in the process of building an NA LS9 416 road race engine for the 5th gen... |
08-20-2019, 05:42 PM | #24 | |
What I’m saying is, an 800hp crank c8 weighing likely 3400lbs minimum, is going to lose if they have the same tires. It is incredibly ****ing obvious that I don’t mean unlimited mods with that motor with a dragged out c8 with slicks and skinnies and no passenger seat is incapable of beating a stock mclaren 720s. Why do I even have to say that. Go ahead completely gut your drag camaro and throw some skinnies on, you’ll probably beat a 720s with 500whp. Acceleration is not rocket science, infact it’s incredibly simple. And a stock 720s has a better power to weight ratio than an 800hp c8. |
08-20-2019, 05:53 PM | #25 |
08-20-2019, 06:16 PM | #26 |
08-20-2019, 06:22 PM | #27 |
it would disagree by a long shot. you didn't even come close to covering all the variables enough to call it a scientific fact. you looked at hp (that you extrapolated/guessed from a rwhp number lol) and weight (while still guessing at the c8) and the tire. that's it.
looked right past the stall converter for one thing. and plenty more and science is still struggling to explain a 650 rwhp 3400 lb car running faster than your McLaren on drag radials. |
08-20-2019, 06:32 PM | #28 | |
Whp Weight 60ft Trap speed Acceleration is traction, hp, weight, and shift times, thats it. It’s incredibly simple How does a dodge demon run 9’s with slicks, skinnies 760whp at 4100lbs? Yet it runs 11 flat on street trim. Hmm maybe being setup specifically as a drag car has a huge advantage? I’m fairly certain a 1500hp bugatti chiron runs high 9’s. Lol thinking a heads/cam drag camaro is as fast as a chiron. |
