11-14-2021, 12:24 PM | #1 |
Drives: 2010 Camaro Join Date: Nov 2021
Anyone got stripes on a sunroof car?
Hey all, I want to add bumblebee stripes to my ride, but it had a sunroof which means I can't run them hood to trunk without interruption.
Has anyone else added stripes to their camaro with a sunroof? I'd be interested to see what it looks like. I was also considering having the roof black with strips on hood and trunk? |
11-14-2021, 03:09 PM | #2 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
Camaro’s only had hood and trunk stripes. Mustangs get nose to tail stripes.
11-14-2021, 03:39 PM | #3 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
The previous owner did it. I wanted to take them off, but my girlfriend likes it that way. That's why they stayed on the roof. As Royal Tiger writes. No Camaro has stripes across the roof. In addition to 4 gen.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
11-14-2021, 05:19 PM | #4 | |
THE Cone Killer
Drives: 2015 2SS/RS BVM; 2016 Vette Z51 Join Date: Jun 2013
The Indy Stripe option is nose to tail. Splitter to diffuser.
ARH Full exhaust w/ HF cats
CAI Cold Air Intake w/ scoop, Gears 3.73 BMR 1.25 inch lowering springs, Trailing Arms, Toe Links, Cradle and offset Diff Bushings, Bilstein Struts, front and rear ZL1 rear Diffuser, Rocker Panels, 1LE Front Splitter Z28 High Wing Rear Spoiler, Tuned by DynoSteve |
11-14-2021, 05:48 PM | #5 |
Didn’t know about the Indy stripes for 5th gens since that’s what I was referring to. Not a fan. I’ve only ever seen rally stripes which are like the 1st gen. Hood & trunk like Chevy & god intended.
11-15-2021, 01:02 AM | #6 |
This is the bumblebee I’m trying to replicate, hence the roof stripes. But I do feel a bit better knowing that it’s not commonplace.
11-15-2021, 05:28 AM | #7 |
My apologies that my opinion post came across as a factual post in regards to the availability of nose to tail stripes. I was going off a discussion years ago that it was said “only mustangs have roof stripes” that I held on to as gospel. I’ve even told that to people in discussions. Sometimes brevity on a forum isn’t always a good thing. Good luck with your project.
11-15-2021, 06:54 AM | #8 | |
I admit that I don't like the lanes on my car at all. The color does not fit completely and when viewed from different angles, a significant difference can be seen. I tried to explain to my girlfriend that no Camaro had stripes across the roof and I really only found 4 genes. what it had.
11-15-2021, 08:29 AM | #9 |
One of my friends Camaros. I think it looks nice, but not for me. Not a stripe guy.
11-15-2021, 08:54 AM | #10 | |
Although this still looks nice. It's worse on my car. Here is the most obvious difference. But from a distance, in the dark, thick fog during heavy snowfall and behind the bushes, it is not so visible
11-15-2021, 09:10 AM | #11 | |
11-15-2021, 10:38 AM | #12 |
Drives: 2011 Camaro SS Join Date: Nov 2017
My 2011 SS has hood and trunk stripes but none on roof. I'm not big on stripes and was going to take them off but I was worried the paint would be faded underneath and it would look terrible. They're also hard to see on a black car (dark gray stripes) so I left them alone.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current |
11-15-2021, 05:52 PM | #13 |
SoCal C5 Family Member
Drives: 1996 Z28 SS & 2014 ZL1 Join Date: Apr 2009
Painted a roof stripe on my 5th gen:
Vance Chula -
1996 Camaro Z28 SS #1688 2014 Camaro ZL1 Coupe #1956 |
11-15-2021, 08:39 PM | #14 | |
THE Cone Killer
Silver stripes on a Blue Velvet Metallic.
