AWE Tuning
Old 12-19-2021, 08:36 PM   #1
Efi69Cam
Drives: 2016 Camaro SS 2017 Yukon Denali
LT1 aftermarket pistons
Does anyone make a 4032 piston for the 6.2? All I’m seeing are 2618. I need a 4.060 bore 11.5cr piston for a stock rod and L8t crank in 4032 for a mild na 6.6 build.
Efi69Cam is offline   Reply With Quote
Old 12-20-2021, 07:15 AM   #2
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I used the Diamond Pistons 11533-R2-8 Chevy LT1 LT4 Gen V Dome and they are almost what your looking for. They are 4.065 and 11.5 compression.
I don’t see what you are looking for. Correct if I am wrong but that size your looking for I have seen in Mopar products not GM builds.
LT4 1.7 Supercharger snout ported & Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 12-20-2021, 05:01 PM   #3
Efi69Cam
Thanks.
My bad, I did mean 4.065 bore. It looks like diamonds entire lt catalog is 2618 though.
Old 12-20-2021, 05:19 PM   #4
BlackbeastSS2
Thanks.
Straight off my box. These are the ones you want for a NA build. I did manley rods, reinforce your heads big time and really go with a bigger cam if your doing these.
Old 12-21-2021, 12:21 AM   #5
s346k
s346k's Avatar
Drives: like an old lady
i plan on using a dome piston. je, wiseco & diamond all offer domes w/ .200 reliefs that bump compression to 12.3 with a factory cc head. i'm hoping to be around 13:1 with aftermarket heads and thinner gasket. otherwise there's no point in swapping pistons for an na build, imho.
2016+ camaro: everyone’s first car
s346k is offline   Reply With Quote
Old 12-21-2021, 12:41 AM   #6
BlackbeastSS2
The swap is needed in my case for pistons because of the Nitrous load. Ring gap on LT1 are not the greatest for power additives.
The fact that reduce weight, and improve strength, durability and ring sealing will help any build with better quality pistons. There’s nothing wrong with someone adding quality pistons to NA build to make it bullet proof and down the road to add a power additive. It’s a costly move but if anyone has the money to do that then I say go for it.
Old 12-30-2021, 06:34 PM   #7
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
What benefit are you looking for in the 4032 grade? I thought most "regular" type automotive pistons were high silicone?
cmitchell17 is offline   Reply With Quote
Old 12-30-2021, 06:37 PM   #8
cmitchell17
But what about all the extra costs and balancing? I can't remember now but I thought the GEN V stuff is also fracture split rod ends so even more machining, or maybe I am thinking of something different. I thought I remember seeing rod bolts in question, but then you hear about all these supposedly extreme RPM stock bottom end stuff.
Old 12-30-2021, 07:17 PM   #9
Trochoidal
Drives: 2017 Camaro 2SS A8
You’re right. Fracture split has both advantages and disadvantages.
https://m.youtube.com/watch?v=5Nm5hNbtfoY
https://www.holley.com/blog/post/eve...n_v_lt_engine/
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“
Trochoidal is offline   Reply With Quote
Old 12-31-2021, 08:13 PM   #10
Efi69Cam
That’s true, most automotive pistons are high silicon, the OEM hyper eutectics for example. There are two main alloys used in forged pistons. 2618 and 4032.
2618 is low silicon. This makes the material more resistant to fractures, but also is softer and requires more bore clearance due to its higher coefficient of expansion. The softness is somewhat alleviated with skirt coatings and ring land anodizing, but they still rattle at cold start and won’t last.
4032 is high silicon, and is more brittle than 2618, but wears better and expands less.
2618 is typically used in power adder applications and 4032 in na. The trade offs for the “toughness” of 2618 are not worth it for what I want to do. A hyper eutectic cast piston like the OEM would work for me.
Old 01-01-2022, 09:46 AM   #11
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I did the Manley Forged Pistons and Rods. I did their blower setup with 10.0 compression.
Old 01-02-2022, 07:36 AM   #12
s346k
s346k's Avatar
you might look into what it takes to hang a stock rod on an aftermarket piston, it may be cheaper or within a couple hundred bucks to use an aftermarket rod, as well. arp fastener requires big end resizing and possibly the wrist pin needs bored.
why are you wanting a forged piston for a "mild" na build? i don't see any aftermarket stuff outperforming a stock piston in that instance. esp if you are planning on keeping the compression so low.
id be looking to see what it takes to use a stock LT1 piston in your case.
Old 01-02-2022, 12:28 PM   #13
Efi69Cam
Stock piston won’t work with the L8t crank, but you are correct that a cast hyper piston would suffice for what I want to do.
There are plenty of 4032 offerings from mahle and others for the 3.780 bore engines that use the stock rod. The stock rods are stronger than most people give them credit for.
Not sure how 11.5 is low comp, but then again I remember when 9.5 was the top end for a pump gas build.
Old 01-02-2022, 01:26 PM   #14
cmitchell17
So is there any improvements we can make by going to a piston with a high expansion coefficient to get better properties to resist cylinder pressure and/or mass reduction? I would think there would be more custom designed alloys for engine piston use but maybe these are. I would sacrifice cold start piston slap noise for better properties.
