02-04-2015, 06:56 PM | #1 |
Do you have the factory amp replacement harness (FARK)?
I need to install my JL sub, amp and speakers in my 2010 coupe with the BA system. I'm replacing the BA amp.
I bought the Camaro Plug & Play RCA Output T-Harness for the Factory Boston Amp V3.0 from sub thump but I need the other plug harnesses in the FARK set. This kit I need is sold out unit April and I can't wait, show season is coming. I need to recreate them myself. Does anyone on here happen the have the Camaro Plug & Play Factory Amp Replacement Kit V3.0 in their coupe they used to replace their factory Boston Acoustics amp? What I'm looking for is a picture of the front and back of the plugs so I can recreate them. This is what plugs I'm referring to: |
02-05-2015, 12:46 AM | #2 |
Drives: 2013 BRM ZL1 Camaro M6 Join Date: Feb 2014
PM me with your shipping address, and select your preferred courier from Fedex, UPS or DHL, and I will forward the following items free of charge ex New Zealand on a freight collect basis ie. you will need to pay international freight and landing
- Exclusive 2010-2015 Camaro Plug & Play Factory Amp Replacement Kit V3.0 [item: 5G-FARK] - 2010-2015 Camaro Speaker Replacement Harness [72-5600] I have the one set only which I never used as I replaced every stock audio component including the wiring. Paying it forward, to the lady that asked nicely, and is not helpless in seeking to recreate them herself. Last edited by NZZL1; 02-05-2015 at 03:35 AM. |
02-05-2015, 02:12 PM | #3 |
PM sent. Thank you NZZL1!
02-05-2015, 11:11 PM | #4 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
When you get the harness can you post pics so I can attempt to recreate the harness for myself?
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
03-21-2015, 11:32 AM | #5 |
More then meets the eye!
+1
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
03-21-2015, 12:31 PM | #6 |
Drives: 2020 2SS SGM - Stock for now Join Date: Aug 2013
+2... I'm used to my aftermarket sound system in my Tahoe. Coming from ~5300 watts with no factory components to the "upgraded BA" system is like pure torture. I have spare everything sitting around but I don't want to cut any wires Sent from my iPhone using Tapatalk |
