09-27-2023, 08:12 AM | #1 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Fluid extractor recommendations
Looking for a recommendation for a pneumatic fluid extractor setup. Don't want to break the bank on it, but really want something that "just works" without a lot of fiddling around.
I've been thinking about this one. What are you guys using? Thanks, Brian
09-27-2023, 08:34 AM | #2 |
I use a stainless turkey baster that has a silicone bulb, but I only use it for brake and clutch fluid.
I've never had that tool, but I have had pretty good luck with OEM tools for jobs I only do occasionally.
09-27-2023, 10:52 AM | #3 |
I've not used much of the OEM tools, but haven't really seen anything bad about them. Reviews on that unit aren't terrible. Appreciate the feedback
10-31-2023, 06:19 AM | #4 |
Just an update. I bought the OEM Tools fluid extractor. It is a well built and seems to work very well. I tested it on a gallon of water and it vacuumed it out with ease and was surprisingly quick.
I am using it with air, and is a bit noisy. That is the air exhaust, and no fault of the tool. Highly recommend
11-05-2023, 04:16 PM | #5 |
Finally got an opportunity to use it. Drained the auto trans and didn’t spill a single drop.
Very happy with the purchase!
11-06-2023, 09:14 AM | #6 |
