04-16-2018, 05:10 PM | #1 |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
Stupid question - Vitesse TC
I have mine mounted in the empty space just under the dic. I have tried numerous methods of adhesive tapes, and seems to stick for a while, then just keeps falling off. anyone have any luck with something else? I am just a few bad thoughts of taking it apart and drilling a small hole and screwing it in...
04-16-2018, 05:15 PM | #2 |
Instagram: Sangstah
When I had a vtc, i just used 3m strong mounting tape from an automotive parts store to hold it and it was fine.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
04-16-2018, 05:46 PM | #3 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
When I had my Vitesse TC I had it in the same spot as well. You have to make sure you are using 3M double sided tape and make sure the surface is clean. Wipe it down with some rubbing alcohol and it should be fine.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
04-16-2018, 06:47 PM | #4 |
What he said ^^^ plus apply some adhesion promoter to the surface after wiping it with alcohol.
04-16-2018, 07:01 PM | #5 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
If the tape is not sticking to the spot you are mounting it, here's the steps I follow whenever mounting something with two sided (3m) tape:
1) Wipe area down with a damp soapy rag (I prefer Dawn) followed by a clean damp rag (no soap); this will remove any pervious cleaners, waxes, protectors, etc. 2) Wipe area down with alcohol pads (I normally go over area at least twice); let dry completely. 3) Apply an adhesive promoter to area. 4) Apply item with tape on it. Following these procedures has worked 100% of the time for me
04-16-2018, 08:28 PM | #6 |
Drives: 2015 Camaro LT Join Date: Sep 2016
I use heavy duty velcro.
04-16-2018, 09:01 PM | #7 | |
Drives: 2019 SS 2019 mustang GT Join Date: Apr 2017
04-17-2018, 06:50 AM | #8 |
Black GFX / Dynatech Supermaxx LT Headers / FR Black Chrome ZL1 Replicas 275/315 / RDP Tune / CAI / VMAX TB / MBRP SS Catback / Gtechniq CSL & EXOV3 / VTC / RX Catch Can / Valentine 1 / Halo DRL / LED Fogs
04-17-2018, 01:02 PM | #9 |
Used the velcro that came with it, then switched to a different velcro after cleaning with rubbing alcohol - did not know about the 'adhesion promoter' - going to get that now. Thanks for all the advise...
