06-03-2016, 03:20 PM | #1 |
2014 1LE
Drives: 1le Join Date: Sep 2013
fumes come out the vents
so I have a 2014 ss Camaro with long headers and stock quad tip exhaust no CAT. I understand it will smell with out a cat but if I turn on the AC you can smell the fumes?
where should I start ?? |
06-03-2016, 03:27 PM | #2 |
Drives: 2015 Camaro 1SS/1LE Join Date: May 2015
I'd start checking for leaks where the headers meet the cylinder heads. If there is a leak the fumes could find their way into the fresh air system.
Doug
USAF Vet 1999-2007 2015 Camaro 1SS/1LE LS3 - Black (Current) 2015 Camaro 2SS/RS LS3 - Summit White (Traded) 2016 Harley-Davidson Road Glide Special - Cosmic Blue Pearl |
06-03-2016, 03:31 PM | #3 |
2014 1LE
ok thanks I will check tonight and see , dumb question how do I check for leaks with out getting burned ?
06-03-2016, 03:32 PM | #4 |
Drives: Camaro Justice Join Date: Jun 2007
Look for tracks, black lines, etc...
06-03-2016, 03:45 PM | #5 | |
http://www.harborfreight.com/mechani...ope-69913.html
Doug
06-03-2016, 04:21 PM | #6 |
2014 1LE
so this might b the problem. this is suppose to have a bigger C clamp correct ?
