Old 12-15-2014, 09:40 AM   #1
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Using factory Aux port & microphone with aftermarket radio
I've searched high and low, and cannot find a straight answer, wiring diagram, color codes, or any other information on how to do this. I'm going to be going aftermarket with my radio, and i know that you can reuse the factory usb via a usb to mini-usb cable (http://www.camaro5.com/forums/showth...74&postcount=4 for those who need this info). Also, if at all possible, in an effort to make this install look as factory as possible, is there any way i can tap the stock microphone in the homelink console for my aftermarket radio?
Does anyone have any information? thanks in advance
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 12-17-2014, 02:00 PM   #2
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
nobody's attempted this? i find that hard to believe?
Old 12-18-2014, 08:00 AM   #3
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
found it myself in a wiring info page. for anyone else interested in doing this, here's the wiring pin-outs:
Ground: Dark Green/White
Left: Yellow
Right: tan/white
Old 03-20-2016, 06:11 PM   #4
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
Update: cannot use factory microphone with aftermarket radio. I've done much testing and with my knowledge after converting factory mic plug to 3.5mm aux (headphone) it seems there's extremely bad interference with the factory mic on an aftermarket head unit. Microphone from factory has a proprietary impedance that will only work with mylink.
Knockoutpie is offline   Reply With Quote
Old 03-21-2016, 09:50 PM   #5
Knockoutpie
Disregard previous post! Factory microphone works very well, there cannot be any interference in the system, you can't talk too loud either because it's very sensitive but it's a great microphone.
Old 03-24-2016, 11:08 PM   #6
Firebreed
Got Boost?
Firebreed's Avatar
Drives: 2011 1SS/RS M6 SLP TVS 2300
Looking at doing this, Where did you tap into those wires at?
2011 1SS/RS M6
MOD List: SLP 2300 Supercharged, Flowmaster AT Cat back, aux 4 guage cluster, 12" kicker sub and Kicker Zx400.1 amp, PFADT Lowering springs
CAI Inc. CAI, Hurst Short throw shifter, JBA 1 7/8 Long tube headers.
Future Mods: 416ci stroker.
Firebreed is offline   Reply With Quote
Old 03-25-2016, 11:06 PM   #7
Knockoutpie
http://www.camaro5.com/forums/attach...1&d=1458965033
Just wired to a 3.5mm mono plug (had to solder) and then used a blue and red wire to connect the mic, I used 2 pins also. I bought a rectifier (idk what that is) but it was from RadioShack and cut the pins off and solders the wires to those and then plugged the pins in the microphone harness
Old 03-26-2016, 02:02 AM   #8
Firebreed
Got Boost?
Firebreed's Avatar
Gotcha, thanks for the pic.
Sent from my SM-G920V using Tapatalk
2011 1SS/RS M6
Old 05-24-2017, 09:59 AM   #9
VeeGeeTea
LEXi is Sassy and Classy
VeeGeeTea's Avatar
Drives: 2012 Camaro 2LT RS Boston Acoustic
Attachment 783984
I need help with this.
I would too like to retain the in vehicle's mic.
Thanks.
VeeGeeTea is offline   Reply With Quote
Old 03-30-2024, 04:05 PM   #10
dnns
Drives: Camaro Conv. 6.2 SS - 2014
Hi,
can someone explain in more detail how to use the original microphone for a aftermarket radio?
Would be infinitely grateful!
dnns is offline   Reply With Quote
