Old 01-12-2024, 11:04 PM   #1
Blazen4884
Drives: Camaro SS
FE3 to 1LE Rear Sway Bar Conversion
Hey all. To give you a little background I've had my camaro 2ss rs for 3 years now. I got it lightly modified. Suspension wise it has H&R lowering springs and I just got new tires F:20/40/265 and R:20/40/295.The car handles better with the wider tires, but I still feel a lot of body roll.
I did some research and it seems like converting the FE3 to FE4 is the way to go for a big improvement. I also heard that getting just the rear 1le / zl1 sway bar with the stock ss front is a pretty good setup (F:23mm / R:28mm).
Would anyone know all the parts needed to run the rear 1le sway bar? Part numbers would be awesome too. From what I can gather I need:
- FE4 rear lower control arm
- FE4 rear drop links
- 1le rear sway bar
Anything I'm missing? Thanks in advance!
Blazen4884 is offline   Reply With Quote
Old 01-13-2024, 02:17 PM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
That’s all that is required. You need the lower control arm because the end links mount further outboard. Nothing else changes. I had to remove mine to install a 15 inch conversion with BMRs extreme sway bar, that’s how I know.
HOJO is offline   Reply With Quote
Old 01-17-2024, 10:44 AM   #3
Blazen4884
Drives: Camaro SS
thank you! Appreciate the confirmation
Old 01-17-2024, 11:03 AM   #4
gtstorey
Does the OEM bar come with new mounts or is that a separate part #. The aftermarket bars typically come with new mounts but I'm not sure about OEM.
Old 01-18-2024, 08:49 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
OEM bars have the mounts on them, but you do have to order the links to the LCA.
Old 01-19-2024, 07:51 AM   #6
hesster
hesster's Avatar
Drives: '10 C5 SS, '77 Bandit T/A
BMR TCA028 or similar has provisions for both. 1st pic used BMR bar and inboard mount. 2nd pic is when I changed to outboard mount with a JPSS sway.
hesster is offline   Reply With Quote
