04-19-2021, 05:42 PM | #1 |
Drives: 2012 Camaro SS A6 SIM Join Date: Nov 2016
Oil weight for dry sump.
Recently installed a ARE dry sump system in my Camaro. Uses stock oil pump for pressure. Currently running 5w-30 at the moment. Any input on what would probably be a a better weight to run? Opinions welcomed.
04-19-2021, 06:51 PM | #2 |
5/30 is fine. I have 5/30 in my C6Z, and it works just fine.
04-19-2021, 08:10 PM | #3 |
Did you alter the factory bearing clearances? If motor is stock otherwise, no reason to change oil viscosity just because you changed from a wet sump to a dry sump setup.
Slick mod, though! I'm gonna have to check that out... |
04-19-2021, 08:56 PM | #4 |
Only thing I hate with the dry dump, is that you have to unscrew 2 bolts to drain the oil (for my c6z at least). Idk how yours is set up.
04-20-2021, 09:44 AM | #5 |
What dry-sump kit are you running?
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
04-20-2021, 11:46 AM | #6 |
Evil Genius of Chevrolet
I was told that if you want to increase pressure you can safely run 0-40 in our engines.
04-20-2021, 03:07 PM | #7 |
04-20-2021, 03:16 PM | #8 |
Tank is mounted in the trunk. Pump itself takes the AC compressors spot.
04-20-2021, 05:42 PM | #9 | |
Filling mine with about 9qts (8 + ~1 for the oil cooler) is already about $150 in AMSOIL every 3k miles. But 14 would be insane! Was looking at doing dry sump in the future to keep the engine happy on the road course/Auto-X.
2013 1SS/1LE
