Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 04-26-2024, 07:58 AM   #15
LancevanceZLE
Drives: 2019 ZL1 1LE
Originally Posted by Vigilante375 View Post
Go off of what your owners manual says. GM updated it in late 2018 early 2019 to 0w40.
Did they send it a letter telling owners that the new recommend oil was that? No.
5w30 is the recommend oil for 2017 - 2018 ZL1s and still is.
This is a stupid take. Use 0W40 on all model years. It's the exact same engine.
LancevanceZLE is offline   Reply With Quote
Old 04-26-2024, 08:11 AM   #16
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
What's messed up is 0W40 Supercar is the oil for Camaros and Corvettes yet the local O'Reilly's and AutoZone etc. don't carry anything but the Euro blend. Super frustrating and a diamond in the rough if you do find it there.
Old 04-26-2024, 10:27 AM   #17
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
What a pain for those who street their ZLE cars and run periodically weekend warrior road course stuff. The manual states use 0w-40 Supercar unless you're racing it, then run 15w-50. Wonder what harm there could be just keeping the 15w-50 in for the street at all times?
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 04-26-2024, 10:51 AM   #18
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I just got the 0w40 M1 SC from AutoZone, some stores have it but I got next day delivery for free and 20% off. Best deal I've found recently.
DaveC113 is offline   Reply With Quote
Old 04-26-2024, 10:53 AM   #19
DaveC113
DaveC113's Avatar
I'd bet it's NBD unless it's cold out, you'll probably get a bit more startup wear at low temps and slightly reduced fuel economy.
Old 04-26-2024, 11:25 AM   #20
Deacon Blues
Drives: 2024 Camaro 1SS M6
Interesting...I can get it from my local Advance and AutoZone, but they won't apply any discounts, it specifically says it is excluded in my cart. Bummer.
Deacon Blues is offline   Reply With Quote
Old 04-26-2024, 12:52 PM   #21
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Better to do it the other way around... just run 0W40 all the time like the regular Z. Especially if you're not a super experience track driver pulling more G's.
I do have to drive around to get it but ALL of them have the Euro blend.
At least you can find it.
Old 04-26-2024, 03:22 PM   #22
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
https://www.walmart.com/ip/Mobil-1-S...e-6/1096252684
24 LT1 M6 Sharkskin Metallic
havelegs is offline   Reply With Quote
Old 05-01-2024, 07:02 PM   #23
SpeZ
Drives: 2019 ZL1,2016 2SS, 2017 320d F30
I believe they just recommend 15w-50 for track only, because of higher cold start wear and tear. The thick oil needs more time to lubricate the cold engine.
I did run last week fresh 0W40 at the track. Oil temp went up to 290°F. Lateral G forces were between 1.2-1.4. I got the OEM 1LE Aero on my ZL1.
What you guys think about the Mobil 1 FS X2 5W50? To my understanding it should work perfectly for street and track use. I probably use it next time at Track and for street use. The 15W50 isn't available for me.
excuse my english
SpeZ is offline   Reply With Quote
Old 05-02-2024, 09:06 AM   #24
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Originally Posted by thecrewdawg View Post
I have a 2018 ZL1 M6.
Only takes a single space and/or mild dyslexia to confuse "Mobil 10w40" and "Mobil1 0w40"
As others have said, 0w40 Supercar is what you want for the street and for non-1LE track use. Once the warranty is up, use whatever oil you wish. And whichever way you choose to go, I'd recommend sending samples to Blackstone-labs to confirm you're getting the result you want out of your oil, given your particular driving conditions and climate.
EDIT: The official GM communication from March 2018 that your son's mechanic friend was talking about is below, reference here: https://www.corvetteactioncenter.com...le.php?id=1389 which clearly mentions Camaro (with an asterisk that excludes 1LE trims I presume to avoid confusion with the 15w50 track use requirement) in the table. Although the document title states only Corvette there was no second document published specific to Camaro ... typical GM_Things(TM). A screenshot of the same webpage was posted on our forums back in 2019: https://www.camaro6.com/forums/showt...0#post10414750 .
Subsequent to this 2018 update, the part numbers and names of the 0w40 have changed from "ESP Formula" to "Supercar"
Gunkk is offline   Reply With Quote
