Old 07-01-2020, 02:59 PM   #1
perfectduck
Drives: 2010 Camaro SS
What can I expect from a tuning?
I'm a noob when it comes to electronics and software in cars. Then again I'm not much of a pro with hardware either. I've been thinking of getting my car tuned for awhile but I am uncertain as to what I can expect in the future should I decide to do it. The only reason I am considering getting it tuned is for the LT headers or just high flow cats. From what I've read not tuning it will cause a CEL if either of these two things are installed. Since this is my daily driver I really I am really looking to keep this long term without compromising the engine. My question is if I tune the car will I be putting the engine under more "stress" causing it to shorten its life? Maybe I'm looking at it the wrong way, I'm almost associating it to installing a turbo but I may be wrong.
perfectduck is offline   Reply With Quote
Old 07-01-2020, 03:53 PM   #2
gtstorey
You will not be putting the engine under more stress, other than the better it runs, the more power you will get if you put your foot in it. It's more likely to have problems if it's not properly tuned, especially if its running lean.
Old 07-01-2020, 05:32 PM   #3
AJARMAN
Drives: 2010 2SS/RS A6
You can expect a nice increase in power. I purchased my headers and tune from Dynosteve and it really woke up my L99. You will not regret the headers or the tune. If you are looking in NC I have talked with SSLSX about cam and dyno and they seem really on top of things.
2010 2SS/RS
CAI Intake
Phastek Air Scoop
Kooks w/ HF Cats
Corsa Sport
DynoSteve Tune
AJARMAN is offline   Reply With Quote
Old 07-01-2020, 06:43 PM   #4
perfectduck
Thank you both for the info. I think I need to look more into this but I'm starting to feel more comfortable with tuning it. I can't say I've read any negative things about tuning so far.
Old 07-02-2020, 06:58 AM   #5
Sparko
Sparko's Avatar
Drives: 2010 Camaro 2SS
Think of tuning as optimizing. Every time you make a hardware adjustment (headers, intake, cams) it changes the air flow and/or fuel delivery. Tuning it just re-balances the air/fuel delivery and spark timing so you are getting optimal combustion.
2010 Camaro 2SS
2018 Charger GT+
2005 Cavailer LS S/C - Sold
'87 HD FXRT - Wrecked pending repair
Sparko is offline   Reply With Quote
Old 07-02-2020, 08:07 AM   #6
perfectduck
That makes sense, from my reading there are different levels of tuning some more mild than others.
Old 07-02-2020, 02:57 PM   #7
Sparko
Sparko's Avatar
Yea when you start pushing for higher levels of power and putting more aggressive parts on you can opt to get more bang out of it with more aggressive spark for example, or dial it back a touch for safety. On the same thread though, you can keep the build reliable if your approaching the mechanical limit, of the valve train lets say, by upgrading the springs or what have you. So the long and short is you're tuned within the mechanical limits of your build. Any credible shop that provides tuning services will do this by nature.
2010 Camaro 2SS
2018 Charger GT+
Old 07-02-2020, 06:35 PM   #8
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Plus most tuners like DynoSteve here will tune it for daily driving. It’s not as a aggressive tune as a drag car.
Bigdumogre is offline   Reply With Quote
Old 07-03-2020, 12:40 PM   #9
perfectduck
Originally Posted by dynosteve View Post
Feel free to pm me or give me a call sir and i can help you with all on your questions
Dynosteve
440 358 5500
Much appreciate it.
Old 07-08-2020, 10:45 AM   #10
jimrhodes
Drives: chevrolet camaro
Originally Posted by perfectduck View Post
I'm a noob when it comes to electronics and software in cars. Then again I'm not much of a pro with hardware either. I've been thinking of getting my car tuned for awhile but I am uncertain as to what I can expect in the future should I decide to do it. The only reason I am considering getting it tuned is for the LT headers or just high flow cats. From what I've read not tuning it will cause a CEL if either of these two things are installed. Since this is my daily driver I really I am really looking to keep this long term without compromising the engine. My essay writers question is if I tune the car will I be putting the engine under more "stress" causing it to shorten its life? Maybe I'm looking at it the wrong way, I'm almost associating it to installing a turbo but I may be wrong.
Feel free to PM me if you still have any questions. I will try to help you.
jimrhodes is offline   Reply With Quote
