02-26-2023, 07:48 PM | #1 |
Drives: 2010 2LT/RS Join Date: Mar 2015
9.5" rim vs 10" rim for the front wheels
Is there any visual differences between the two? I currently have OEM ZL1 rims on my car and plan on keeping them. I like the flush look with my current setup. However, looking into other wheel options to go back and forth with. The sizes I want are 10x20 front and 11x20 rear which is what I currently have. I keep coming across 9 to 9.5" rims for the front and wondering if it is really noticeable going the smaller width?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
02-27-2023, 04:10 PM | #2 |
125 views and no one knows?
2010 2LT/RS
02-27-2023, 06:28 PM | #3 |
Drives: 2010 Camaro 1SS Join Date: Nov 2015
Do you know what the offsets on the other wheels you are looking at?
The offset will dictate how it looks almost as much as the wheel size itself. The ZL1 wheels should be the following 2012-2015 ZL1, 2013-2015 SS 1LE offsets: front, 20x10 ET23 rear, 20x11 ET43 Use this site https://tiresize.com/wheel-offset-calculator/ and plug the numbers in.
02-28-2023, 01:50 PM | #4 |
The offset for the rims I’m looking at are…
Front 9.5 is + 22 and the rear 11” offset is + 43. Sent from my iPhone using Tapatalk
2010 2LT/RS
02-28-2023, 06:34 PM | #5 |
I know its not exactly what you are looking for, but here are a couple pictures of my front 20x9 (+27mm offset) with 275/40's.
02-28-2023, 08:33 PM | #6 |
Thanks for sharing. Not exactly the same wheel size I'm looking for. Although they do look flush with the fenders on your Camaro.
2010 2LT/RS
03-01-2023, 07:30 AM | #7 |
Yeah, my front tires are pretty much even with the fenders...which is exactly what I was going for. I just wanted to be conservative since I'm lowered 1.25" and didn't want to have to deal with any rubbing. I would think with the difference in offset (and assuming all other factors the same), 9.5 wheels would end up being almost in the same place.
03-01-2023, 10:40 AM | #8 | |
I am also lowered at 1.5” using DSE lowering springs with no rubbing using the factory oem rims. Sent from my iPhone using Tapatalk
2010 2LT/RS
03-01-2023, 06:45 PM | #9 | |
I plugged the numbers in and this is what I get. Looks like everything will remain the same. Hmm...
2010 2LT/RS
