07-02-2018, 01:27 PM | #1 |
Camaros Of Northwest Ohio
Reinstalling OEM brake pads for CF8 NCM Track Event
I currently have the PowerStop Z26 low dust pads on my car. I have been advised here and later verified from a call to PowerStop that I should reinstall the OEM pads for the track event at CF8. I was planning on roughing up the old pads a little with 80 grit sandpaper and a sander. Is this the right approach and should I follow a bedding procedure?
Thanks, Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
07-02-2018, 01:43 PM | #2 |
yes i did the same thing and also washed my rotors with soap and water and was fine...i also purchased a set of track day pads for my next event and will be using those instead of the stock ones or z26 pads
07-02-2018, 02:47 PM | #3 |
Yes, you were the one that provided the advice!! Thanks
Bill
07-02-2018, 03:33 PM | #4 |
haha oh yea sorry but yes sir u will be good u also going to install the track package in the trunk and upgrade your brake fluid?
07-02-2018, 05:42 PM | #5 | |
Are you going to CFest8? Bill
07-02-2018, 05:47 PM | #6 |
its the lil brake duct/backing plate package that should have been in the trunk of the car. Its for track use only and i would recommend swapping brake fluid also but you do have the 6 piston kit so you should be better...
as for camaro fest i live in california and i work monday to friday in sales so probably wont happen this year but maybe sometime! lol
07-02-2018, 06:30 PM | #7 | |
Again thanks for the advice. Bill
07-02-2018, 06:38 PM | #8 |
oh ok weird he should have included it...you can always purchase it from the dealer or wildhammer motorsports i think its only $40-50 but im sure you will be fine unless you are driving at 100%
07-09-2018, 08:27 AM | #9 |
Drives: '17 Red Hot 2SS 6MT Join Date: Mar 2018
On the same topic, would I be better to put the stock pads back on the front for track duty rather than the Hawk HPS pads that I currently have installed?
07-09-2018, 02:23 PM | #10 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
At a minimum you'll want to re-bed after switching pads, but as others have stated cleaning the rotors prior to re-bedding is fine too.
2017 SS 1LE.
07-09-2018, 03:19 PM | #11 | |
07-10-2018, 06:55 AM | #12 |
Shouldn't need to do the whole procedure in the GM documentation again (light burnish, heavy burnish, then light burnish). I'd think you'd be OK with something between the GM "heavy" burnish procedure and the hawk procedure. Worst case if you don't get it fully burnished on the street the first track day session will finish it up. Just don't dive in and brake super hard/late on your first corner
2017 SS 1LE.
07-10-2018, 08:34 AM | #13 | |
