08-26-2011, 10:06 AM | #1 |
Cog driven maggy question?
So I am currently running an overdriven rear pulley setup on my maggy 2300. What are the pros/cons of cog driving it?
08-26-2011, 10:21 AM | #2 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
you're going to be making higher boost, so be sure you dont go with a really small pulley size on the front on a stock engine or you could run into problems. The cog drives also whine more FYI.
Can you explain your question more; or what you are trying to do?
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
08-26-2011, 10:31 AM | #3 |
i would like to get more whine out of the charger!! i like it! My motor is stock but im not running too small of a pully on the maggy. I will find out what sizes im running exactly later today.
08-26-2011, 10:39 AM | #4 |
Drives: 2010 Camaro Join Date: Feb 2010
Seems like you need the 1:1 cog drive. Jessika at Maggie should be able to hook you up. If you OD the rear cog you will gain a few lbs. of boost. Which on a stock engine may not be wanted. You can OD the rear cog and the pulley up (going to a bigger pulley) the fron to compensate and bring the boost back down.
08-26-2011, 11:25 AM | #5 |
Drives: Car Join Date: Jun 2010
3.8" pulley up front and OD in the rear with 1&3/4 LTs on mine ran me at 11PSI.
08-26-2011, 03:24 PM | #6 |
mine is an overdrive in the rear and a 3.6 in the front. and my car is a L99
08-26-2011, 03:35 PM | #7 |
How are you running 3.6 up front an OD Cog Drive in the back and getting 9PSI without running a cam, lower compression, etc?
08-26-2011, 04:19 PM | #8 |
Mines not cog, just overdriven pulleys in the rear. It's at 9 psi, is that really low? Im not sure how much differences there are between the auto and manual motors, but mine is the auto. What is the max psi a stock motor can handle (L99)?
08-26-2011, 04:21 PM | #9 | |
I can't speak to the stock boost safety thing other than to say it's more complicated than a simple PSI number... you can kill a motor on low boost with bad tune, fuel, etc.. |
08-26-2011, 04:31 PM | #10 | |
08-26-2011, 04:36 PM | #11 |
I have a set a vendor sold me and told me I'd be fine with.. I wasn't.. It made 11 PSI (was told about 9.5) with all my mods even on a 3.8" stock front TVS pulley. So, now I have a 375.00 paper weight that I can't use due to too much boost on a stock internal LS3. I can't seem to sell them either..
I can't tell you how they'd work on your car and I don't want to steer you in the wrong direction by giving you the wrong data and you end up blowing something up.. Just telling you what I dealt with.. The two people I talked to over at Magnuson were surprised I was trying to run them on a stock block as they don't really recommend that for the reasons I saw. The 1:1 cogs are what you want for just sound and more belt grip, but at your boost level I doubt you're seeing slippage in the first place... But, if you do want to go with the OD cogs.. I will sell you my set for 300.00 shipped to you. They don't come with the new machined fuel rail for clearance as I bought them before that was resolved, but your local shop shouldn't' have any issues clearancing your passenger side fuel rail. Mine were only on the car for the 1 dyno pull where the engine start pinging and pulling timing.. I personally wouldn't run 11-13 PSI even with a good fuel system on a stock set of pistons.. I'm sure you could do it and it would live for a while, but that's a lot of boost on a stock motor, even the slightly lower compression L99. One little thing goes wrong at that rating and your engine will most likely fail. |
08-26-2011, 04:55 PM | #12 |
Does it take a lot of time to remove the and put the cogs on or does the blower have to be removed?
08-26-2011, 04:59 PM | #13 |
I believe on our cars they can be changed out while the s/c is still on the car. I can't give a time estimate. There are a couple threads on the topic in the FI area that could better answer that.
08-26-2011, 05:12 PM | #14 |
But if I have over drive and I go to 1:1 cogs it would be a step back wouldnt it?
Similar Threads | ||||
Question: Cars only driven by one wheel? | JMROD | General Automotive + Other Cars Discussion | 17 | 08-29-2010 04:04 PM |
Question about RS DRLs--PWM driven by BCM?? | Hephaestus1 | Cosmetics and Lighting Modification Discussions | 6 | 06-29-2010 12:07 AM |
Custom wheel offset question ... | Bowtie Junkman | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 04-23-2010 05:16 PM |
Question Involving 4.10 gears & Bushings | Deric884 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 02-13-2010 06:53 AM |
Fbodfather/ Anyone who's driven the new Camaro... question? (just curious) | scotchsride09 | 5th Gen Camaro SS LS LT General Discussions | 13 | 09-23-2008 06:45 PM |
