07-03-2022, 02:02 PM | #71 |
Drives: 2022 1SS 1LE 2024 LT1 2002 Z28 Join Date: Jun 2022
Looks like 2022 production is a bit under 12,000:
https://gmauthority.com/blog/gm/chev...sales-numbers/ |
07-03-2022, 06:19 PM | #72 | |
Drives: '22 Summit White ZL1 A10 Join Date: Aug 2019
Is that manufactured or sales as it's labeled.......
2022 ZL1 Summit White A10
2020 GT350 Heritage Edition-Chassis L0350 2019 ZL1 Summit White M6 2018 Hellcat White Knuckle M6 2016 Hellcat GoMango A8 2002 Dodge Viper Viper Red 2002 Corvette Z06 Millennium Yellow 1998 Dodge Viper Viper Silver Metallic |
07-27-2022, 06:31 PM | #73 |
Drives: Chevy Camaro Join Date: Jul 2022
2022 Camaro
Can anyone direct me how follow the build on a 2022 Camaro. I've been given an order # from the dealer but no other information yet.
08-15-2022, 02:52 PM | #74 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I only count 315 crush oranges or so, am I missing something? I would've thought much more were made, there 5 in my small town including me now, so can't be that rare right?
08-16-2022, 06:07 PM | #75 |
2021 1SS Build counts (orange crush inquiry)
GM built a total of 2,036 Chevrolet Camaro 1SS for the 2021 model year.
Of those 2,036, 971 were equipped with the 1LE performance package. Of those 2,036, 830 were equipped with the 6-speed manual transmission. Of those 2,036, 73 were equipped with the Orange Crush exterior paint. Unfortunately, we can not cross-tabulate to identify how many of the 2,036 had the 1LE package AND the 6-speed manual trans AND the Orange Crush paint. Mine is 6spd, Crush, 1LE -Im guessing only one of 20 w/ that combination |
08-28-2022, 09:42 PM | #76 | |
Drives: 2020 3LT Camaro 3.6L 1LE Join Date: Feb 2020
You don't happen to have the numbers for 2020 1LE Crush? GMH never responds. |
11-22-2022, 10:10 PM | #77 |
Belt came off and car overheated
I’m not sure where to post this but I need help!!!
While I was driving on the highway today, somebody was driving slow in front of me so I stepped on it to get around them a couple moments after a message popped up on the dash stating check charging system and shortly after that a message popped up and said engine overheating please pull over and idle engine when I pop the hood. I found my AC belt completely off and ripped to shreds and my main drive belt sitting there in between my fan shroud, and my crank pulley. I haven’t took it to the shop yet, but you can smell the hydrocarbons in the coolant.😢🫠 Long story short, have any of you guys had any experience with belt slipping off when you step on it. PS… the car has a RotoFab cai, Msd mani, NW 103 tb, speed engineering headers, dsx flex fuel, BTR Stage 2 cam kit, and LME Ported heads |
06-03-2023, 03:22 PM | #78 | |
Drives: Audi A7 BMW K1200S MV Agusta F4 A Join Date: Jun 2023
Belts Being Thrown Off From Your 2022 Camaro
How old is your car? Is it a year or less old? Sounds odd that a belt would let go, unless there is a quality problem with either the belt (either the main accessory drive belt, or the A/C drive belt). One or the other (or both) belts should be feeding the water pump. The next thing to investigate is the idler tension pulley. The pulley arm is spring-loaded to keep tension on the belt. If this tensioner is defective, then the belt could pop off the pulleys and get jammed in with the other belt and cause it to pop off, too. I suspect you have a valid warranty claim that should be covered by the new vehicle warranty. I'd take it to the dealer and let them figure it out. This is provided as a long time shade tree mechanic and engineer. Your car particulars may include other features I am not familiar with, as I do not yet own a Gen 6 Camaro. Last edited by AZ Shane; 06-03-2023 at 03:26 PM. Reason: Correcting misspellings! |
08-22-2023, 02:46 PM | #79 |
Drives: Chevy corvette Join Date: Jun 2022
how many 2023 zl1 were made
08-24-2023, 06:52 PM | #80 |
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
11-15-2023, 08:30 PM | #81 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
Just to consolidate the years not in the OP:
2021 ZL1 https://www.camaro6.com/forums/showp...7&postcount=11 2022 ZL1 https://www.camaro6.com/forums/showp...4&postcount=37 2023 ZL1 https://www.camaro6.com/forums/showp...3&postcount=86
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
02-01-2024, 11:44 AM | #82 |
Drives: 2023 1LT Convertible Join Date: Jan 2024
For those of you interested, I thought this might be a good place to post this. You can get your monroney sticker from GM here:
https://cws.gm.com/vs-cws/vehshop/v2...NDAEK6RG121473 You just have to replace the VIN # in the link with your own.
03-03-2024, 07:44 AM | #83 |
I tried using that link with my Vin but it isn't working. Says error and if I just put in the beginning link to get to the website o look for it and it says access forbidden. What am I doing wrong?
03-05-2024, 03:23 PM | #84 |
Drives: 2011 Silverado Join Date: Sep 2019
2018 2SS Convertible
I figured I'd add to the thread what I was told about my Black 2SS and its options after contacting GM Heritage with my VIN # last month (February '24).
As many others have pointed out, it's a shame it can't be broken down to a specific number in this computer age. However, at the very most my car is in the low 200's, so I guess that's better than nothing. Also, the build sheet for my car indicates the "dealer installed" factory RPO codes referenced below which might help some of you out if you're wondering about a specific option. They replied: That being said, our records indicate the following: 56,839 Camaros were produced in total for the 2018 model year:
2018 Black 2SS Vert
Born on June 7, 2018 GM ground effects, lower grill and splitter Stock for now |
