09-13-2019, 12:44 PM | #1 |
Drives: 16 2.0 red Join Date: Feb 2018
removing enblems
i have a 16 ats coupe , that i would like to remove the enblems from the trunk led without messing up the paint, can somebody tell me how, posting over here , as there is is more traffic.
09-13-2019, 12:50 PM | #2 |
Just use a strong fishing line and simply "saw" the dual sided tape off underneath the emblem, always pulling towards yourself and not the paint. It may be easier if you warm up the area with a hairdryer beforehand. Once the emblems are off, clean up the area with rubbing alcohol or Goof Off, using a soft microfiber cloth.
If they are attached with clips (unlikely, but I don't know the ATS), you need to work around the clips with the line, then very carefully pop the emblem off with a plastic trim tool.
09-13-2019, 01:29 PM | #3 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
People get entirely too impatient when they’re taking off a badge....
Get some GOO GONE from the drugstore… Not GOOF OFF -That stuff is dangerous on paint, it can cloud the clearcoat. Get a medicine eyedropper or a bottle that secretes drops and “marinate” the logo every 15 minutes for an hour to an hour and a half. Then use the fishing line talked about above to saw it off and you can remove the residue with your fingers… If you marinate the logo instead of just going at it, the Logo will almost fall off the car by itself. Best fishing line to use is 20 pound braid…
09-13-2019, 01:50 PM | #4 | |
09-13-2019, 02:30 PM | #5 | |
09-13-2019, 03:08 PM | #6 |
fsh line
Tried the fish line way, worked very well. thanks
09-25-2019, 01:30 AM | #7 |
Drives: 2016 camaro Join Date: Mar 2018
For the sticky residue, I used 3m adhesive remover.
09-27-2019, 10:48 AM | #8 |
The legit way to do it....
Goo Gone for an Hour followed by a heat gun at a SAFE distance don't shove it right up on the car itll come right off with easy pull
09-29-2019, 10:12 AM | #9 |
Drives: 2016 2LT V6 Garnet Red Join Date: Feb 2017
That leaves room for damage, if you follow the method above it's very difficult to do any damage. I'm a complete idiot and I got my rear badge off with a similar process (I did the line first then goo gone on the remainder.
09-29-2019, 12:22 PM | #10 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
Put painters tape all around the emblem as well.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
09-30-2019, 06:02 PM | #11 |
I've removed every badge on my car with this method....the weather has done more damage to the car than this lol but everyone has their preference
09-30-2019, 06:04 PM | #12 |
i just use a hairdryer lol worked just fine on my side emblems
