BeckyD @ James Martin Chevy
Old 09-11-2019, 08:50 PM   #1
B_rad1969
Drives: 2013 2lt
Shaking on heavy braking
Just got new rims and tires. Regular size 1LE rims and tires. 305's in the rear. Taking it back to the tire shop Saturday. What could cause a bit of a shake in the vehicle when I brake kinda hard? Something is not balanced because I get a vibration on the HWY. Maybe it's exaggerated because something's not balanced...
B_rad1969 is offline   Reply With Quote
Old 09-11-2019, 09:05 PM   #2
MadAmos
Drives: Cadillac ELR, 2019 Camaro 2SS A10
Wheels could have incorrect center bore, damaged center bore, installed improperly, over tightened or a combo of the above. Shaking under braking may indicated tone or more rotors is damaged (warped).
Other possibilities would be a defective wheel or tire.
Amos
2019 2SS, White A10
MadAmos is offline   Reply With Quote
Old 09-11-2019, 10:21 PM   #3
B_rad1969
Drives: 2013 2lt
That narrows it down!😁
Old 09-12-2019, 08:06 AM   #4
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Do the new wheels have the same center bore? Most after market wheels do not.
ssmofo is offline   Reply With Quote
Old 09-12-2019, 08:12 AM   #5
MadAmos
I was a bit tired when I posted that I would suspect the wheel centering first. The shake when braking may indicate the rotors have been damaged.
Amos
2019 2SS, White A10
Old 09-12-2019, 11:48 AM   #6
B_rad1969
Drives: 2013 2lt
I don't feel it in the front end like the steering wheel. They are MRR rims. I don't know if they have any trouble with the rims or not...
Old 09-12-2019, 12:57 PM   #7
ssmofo
ssmofo's Avatar
I had the same thing happen when I bought my 99 TA it had some replica C5 wheels on it, they were centered with the lug nuts, alway vibrated, I shit canned those and bought Forgestars, they came with plastic centering rings, which I quickly upgraded to Aluminum, vibrations are now gone.
Old 09-12-2019, 06:59 PM   #8
MadAmos
Rear rotor problems can make the car shake without feeling it in the steering.
Amos
2019 2SS, White A10
Old 09-12-2019, 08:52 PM   #9
B_rad1969
Drives: 2013 2lt
Yes but the odds of it happening at the same time are about zero. For whatever reason, it hasn't done it hardly the last week. The first time it happened it freaked me out. I'll have to look at the rims. I'll have to look at the inside of all the rims to see if I see any wear from rubbing the hubs.
Old 09-13-2019, 10:04 PM   #10
WTFO
Drives: 2018 Camaro 1SS
Try the people that mounted the tires used a damned air impact and over torqued the lug nuts and warped something like rim / rotor.
Never deal with folks that don't use a accurate torque wrench on lug nuts and torque properly by hand.
WTFO is offline   Reply With Quote
Old 09-25-2019, 12:43 AM   #11
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
you would be surprised at how many shops dont have or dont know how to use a torque wrench.
Old 09-25-2019, 01:24 AM   #12
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
Over torqued rims will warp the rotors!
Sweptwing is offline   Reply With Quote
