BeckyD @ James Martin Chevy
Old 07-18-2019, 04:48 PM   #1
retmil
Drives: 2022 Wild Cherry SS
Memory Seat Issue
The memory seat function on my 17SS works sometimes and not at others. The exit feature works fine but when I get into the car I hit the start button for the seat to move forward and sometimes it does on the first start of the day and then not afterwards. Any ideas?
retmil is offline   Reply With Quote
Old 07-18-2019, 08:09 PM   #2
Beamz27
Beamz27's Avatar
Drives: 19 Satin Steel 2SS A10
My 17 did this and now my 19 does too. Pain in the ass
Beamz27 is offline   Reply With Quote
Old 07-18-2019, 09:26 PM   #3
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
Some sort of safety feature? I only use it when the car is off. Wanna be on the pedals before I fire it up. Clutch not fully down and on the brake could be a mess.
2021 Crush ZL1 1LE
gotroost is offline   Reply With Quote
Old 07-19-2019, 03:13 PM   #4
retmil
The feature is not used when starting the car..just press the run/start button without depressing the clutch and seat should move forward. Issue is that it does not do so all the time.
Old 07-19-2019, 03:56 PM   #5
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
Hmm, are you using the same keyfob all the time, or do you use both keyfobs?
SPARTAN sui is offline   Reply With Quote
Old 07-22-2019, 02:37 PM   #6
retmil
I use the same fob all the time.
Old 09-17-2019, 10:03 AM   #7
HWG
Drives: 2018 SS Convertible
I have an 18 2 SS is there something that sets it to go once the car is started ....I have to hold the button until I it gets to position ...?
HWG is offline   Reply With Quote
Old 09-17-2019, 10:18 AM   #8
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
Easy exit will always work but the EPB must be set for the seats to move into position.
17’&18’s work the same way but the 17’ manual doesn’t tell you that the park brake is required
To clarify, auto trans must be in park OR manual trans the park brake needs to be set.
Sweptwing is offline   Reply With Quote
Old 09-18-2019, 02:55 PM   #9
retmil
Sweptwing you are the man!! You are absolutely correct. The parking brake must be on for the memory seat option to work on entry and the manual does not mention that. I have been fighting with that issue since I bought the car new. Again - thanks for the helpful info!
Old 09-18-2019, 03:19 PM   #10
Sweptwing
Sweptwing's Avatar
Retmil, you are totally welcomed! I too struggled to figure this out.
One other tidbit, you can enter the vehicle set the epb and you’re good to go, the car doesn’t need to set in the garage with epb set.
Old 09-18-2019, 04:28 PM   #11
retmil
Yep I found that out also.
Old 09-22-2019, 02:56 AM   #12
Corbu
Drives: Camaro 2SS
I have a 17" automatic and do not usually use the parking brake. Very rarely. And yet, the seat comes forward every time, but when I get in the car I always have the foot break pressed before starting the car. Try that too if you don't want to use the parking break.
2017 2SS stock
Corbu is offline   Reply With Quote
Old 09-23-2019, 06:03 AM   #13
HWG
..yep went into the settings and turned on the seat memory ...all is well
