05-18-2019, 07:31 AM | #1 |
Drives: 18 2 SS 17 jeep grand cheerokee Join Date: May 2019
How to program memory seats
How do I program memory seats? I have pushed set button then 1 , held both at same time, and every other combo I could think it might be. I guess I’m not holding tongue right.
05-18-2019, 07:37 AM | #2 |
Drives: 2016 2SS 8AT Join Date: May 2018
I had to do it a few times in a row for mine to stick. Going off memory put the seat where you want and hold the set and the number you want it saved as untill it beeps.
05-18-2019, 08:05 AM | #3 |
Drives: 2019 Camaro 2SS Join Date: Jan 2019
Press and release the set button, you should here a beep. Then press and hold the 1 or 2 button until you hear 2 beeps.
https://www.chevrolet.com/how-to/memory-seats |
05-18-2019, 09:21 AM | #4 |
Thanks guys I’ll try it again several times in a row. It beeped before but didn’t save. But I also had to change and then reset and save the mirror tilt memory a few times for it to save
05-18-2019, 12:52 PM | #5 |
Drives: 2019 Camaro 2SS A10 Join Date: Feb 2019
Are you doing it while car is running or in accessory mode? I was having trouble while trying it without the car running. Tried it while it was running and was able to program 1 & 2, and exit position.
2019 2SS: A10, Satin Steel Gray Metallic, MRC, Nav.
05-18-2019, 10:11 PM | #6 |
Figured out prob was I just pushed the button and let go right away. The memory was programmed the whole time I just needed to hold the #1 button down. Oops used to ram and wife’s Jeep
05-19-2019, 10:01 AM | #7 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
The easy enter/exit feature allows the seat to move back or forward upon entering or exiting the car, but the ebrake must be on for it to function.
05-20-2019, 07:25 AM | #8 |
Drives: 2018 SS 1LE Join Date: Aug 2018
I wish my 1SS 1LE had this. Do the memory seats have the option to move the seat all the way back when you turn off the vehicle? Wife had a KIA that did that and it was so nice for getting in and out.
05-20-2019, 07:30 AM | #9 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
yep!
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
05-20-2019, 01:43 PM | #10 |
2018 ZL1 1LE
Yes! Just engage the ebrake before you exit the car for it to function
05-20-2019, 03:09 PM | #11 |
Drives: 2017 Camaro RS Fiftieth Anniversary Join Date: Oct 2017
I have a 2017 RS A8 and have no need to use the ebrake to activate the Easy Exit feature. Once I set it to "on" in the Vehicle Personalization function, it activates automatically when the car is turned off and I open the door. The manual says it will also activate if the car is turned off with the door open as well although I haven't tried that.
05-20-2019, 03:51 PM | #12 | |
