Old 11-17-2019, 05:39 PM   #1
Camaro Rules
Camaro Rules's Avatar
Drives: 2018 2SS Camaro
A Liitle Help on Rim/Wheel Offset...Please
Camaro Rules is offline   Reply With Quote
Old 11-17-2019, 09:57 PM   #2
Markoz28
Drives: 18 ZL1 nightfall grey A10
Depends on the width and height of the new wheel.
Markoz28 is offline   Reply With Quote
Old 11-18-2019, 03:50 PM   #3
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
wookwook is offline   Reply With Quote
Old 11-19-2019, 07:58 AM   #4
JT58
Drives: Former 2016 Camaro 1LT
In laymans terms the offset is the distance from the center of the wheel of the face that mounts to the wheel. The more positive offset, the more the wheel will be inwards in the fender well. How much the wheel sticks in or out from the fender depends on the wheel width and the offset. Wheels are available in so many widths and offsets it can be confusing. I have bought aftermarket wheels in the past that stick out or in too much.
I wanted a perfectly flush look with a square set up on my Camaro. I wanted wider than the stock 8.5" wheels. I ended up going with 10" wide wheels. It took me the longest time of research, looking at available wheels and the different offsets, adding and subtracting, comparing to my stock wheels to try to determine how much more they would stick out. So I went with a shop that buys blank wheels- no bolt pattern and extra material left on the hub for machining the precise offset desired. I got the exact look I wanted with a 10" wide wheel and square set up, not staggered. I am so please with how it came out. End result was 10" wide wheel machined to a 28 MM offset. See my post on Stance FS-08.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
