Roto-Fab
Old 03-23-2011, 12:33 PM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
JANNETTY RACING UPDATED CUSTOM TUNE INSTRUCTIONS
JANNETTY RACING CUSTOM TUNE INSTRUCTIONS
When you Purchase an SCT X3 Hand Held Tuner from me you get 1, 93 OR, 1, 91 Octane Tune For Free for your simple bolt on mods, exclusions apply for cams, superchargers and nitrous.
PLEASE SPECIFY OCTANE WHEN REQUESTING CUSTOM TUNE, DEFAULT IS 93 OCT.
Additional Tunes with minor changes are available for 50.00 each, i.e. Second tune for a different Octane.
Your new SCT X3 will come to you Blank, You will need to connect the device to your car and Upload Stock tune file, here is how, plug the device in to your OBDII port, select Program Vehicle, Using the left arrow scroll left to UPLOAD STOCK, it will prompt you to turn on the key, do so, and hit select.
Your tuner came with a disc with Free Software called SCT Device Updater software, install this in your home or laptop computer Before you connect the device to your computer.
Then After you install and OPEN SCT Device updater software, you can connect your X3 to your computer, Drivers should install automatically, then Get Stock File, Click Browse, Find your Desktop and Click Save.
Go to your Desktop, there will be 3 files, Select the one with Your VinNumber.sul and email it to me tedj@jannettyracing.com along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, List of performance modifications, and Octane you want to run your car on, i.e 93 or 91.
PLEASE RE: READ LAST STEP, I CANNOT TUNE YOUR CAR WITHOUT THIS INFORMATION.
Then I will send you back a custom tune file for your mods.
Save the file to your desktop, it will be, YOUR NAME JRE TUNE.cef
Again open SCT Device Updater, Then, connect your X3 tuner, select Load Custom Tune File, Browse to your tune file, exit when finished.
Connect to your car, Select Program Vehicle, scroll left to Custom Tunes, Select JRE tune and follow the on screen prompts.
I have developed Dyno Proven tunes for all of the Product I sell, So Unless I instruct you to do so Datalogging will NOT be necessary.
If I instruct you to Datalog your car, The best way I found is to use a laptop on the seat, First Open the LiveLink Software then connect the X3 to your laptop, then connect the X3 to the OBDII Port of the car, With the Car RUNNING, Hit the connect button, a list of PIDs will come up, you will have to scroll through them selecting the Items below.
Even thought they may not be named exactly as I listed them, I want you to select the following, but try not to select anything Not listed or doubles of any of the items listed.
You may have to test several PIDs to see which ones work best or work at all on your car.
Once you find a list that works well Save Livelink Configuration file for future use.
Engine RPM - RPM
ECT engine coolant temp – ecteng clt tmp
TPS throttle position or pedal position – acc pdl pos 1s
IAT intake air temp or Air intake temp – intk Airtmp
MAF Mass Air flow Hz – Maffre 125
TIMING spark cylinder 1 – ign Tim Adv4#1cyl
KNOCK RETARD – knk ret
Short Term Fuel Trim bank 1 – stf tri b1
Short Term Fuel Trim bank 2 – stf tri b2
Long Term Fuel Trim bank 1 – ltf tri b1
Long Term Fuel Trim bank 2 – ltf tri b2
Pleas ONLY Select the PIDs Listed, Extra PIDs Slow Down Datalogging and give me useless information.
Names can vary from computer to computer but you get the Idea.
Go find a open road somewhere, 1/2 mile or so long would be great, from a stop drive the car 1/4 throttle up through the gears normally shifting at about 4500 RPM.
Then repeat at about 1/2 throttle to 5500 RPM Speeding is not recommended or necessary 1st and 2nd gear are fine if you do not have the room.
Stop, and Save Datalog As, to your desktop.
Email me the log file along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, and list of performance modifications.
PLEASE RE: READ THIS STEP, I CAN NOT REFINE YOUR TUNE WITHOUT THIS INFORMATION.
If you have other questions about SCT this is the entire FAQ section http://www.sctflash.com/support/inde...goryid=3&nav=0
REMEMBER WHEN YOU PURCHASE YOUR PARTS FROM ME CUSTOM TUNES FOR THOSE PARTS ARE FREE.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 03-23-2011, 01:00 PM   #2
2010 Indy Pace Car
NCCOA Ch 1
2010 Indy Pace Car's Avatar
Drives: 2010 Camaro 2SS/RS - Z4Z # 44
Thank you Ted. Looking forward to receiving the SCT and TB in the mail and then uploading your tune shortly afterwards. I appreciate your outstanding customer service which, for the record, is what brought me on board as a new customer.
. ADM CAI,-ARH, JARHEADBOB and MAX, LINGEFELTER TB,
SS CEK,
JANNETTY RACING, RPM Motorsports
2010 Indy Pace Car is offline   Reply With Quote
Old 03-23-2011, 01:10 PM   #3
JANNETTYRACING
As they say down south, We Aims to Please.
Thanks.
Ted.
Old 03-23-2011, 01:40 PM   #4
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Dose this work for the v6 also
chevy 3 is offline   Reply With Quote
Old 03-23-2011, 01:41 PM   #5
JANNETTYRACING
No, Sorry No V6 support at this time.
Old 03-24-2011, 07:38 AM   #6
MG
MG's Avatar
Drives: 2011 Camaro
So, this tune will cover both engine and A6 tranny?
MG is offline   Reply With Quote
Old 03-24-2011, 07:50 AM   #7
NickJRE
NickJRE's Avatar
Drives: Nothing Fun.
Correct both the Engine and Trans..
NickJRE is offline   Reply With Quote
Old 03-24-2011, 07:55 AM   #8
pnltnc1
pnltnc1's Avatar
Drives: 2010 Camaro SS
Man I'm really wanting you tune my vehicle..just worried about the warrenty.
When you Purchase an SCT X3 Hand Held Tuner from me you get 1, 93 Octane Tune For Free for your simple bolt on mods, exclusions apply for cams, superchargers and nitrous.
Additional Tunes with minor changes are available for 50.00 each, i.e. Second tune for 91 Octane.
Your new SCT X3 will come to you Blank, You will need to connect the device to your car and Upload Stock tune file, here is how, plug the device in to your OBDII port, select Program Vehicle, Using the left arrow scroll left to UPLOAD STOCK, it will prompt you to turn on the key, do so and hit select.
Go to your Desktop, there will be 3 files, Select the one with Your VinNumber.sul and email it to me tedj@jannettyracing.com along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, and list of performance modifications.
PLEASE RE READ LAST STEP, I CANNOT TUNE YOUR CAR WITHOUT THIS INFORMATION.
If I instruct you to Datalog your car, The best way I found is to use a laptop on the seat, First Open the LiveLink Software then connect the X3 to your laptop, then connect the X3 to the OBDII Port of the car, Then Hit the connect button, a list of PIDs will come up, you will have to scroll through them selecting the Items below.
Once you find a list that works well Save Configuration file for future use.
Engine RPM
MAF Mass Air flow, grams per second
KNOCK RETARD
Stop, and Save Datalog As to your desktop.
Email me the log files along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, and list of performance modifications.
PLEASE RE READ THIS STEP, I CAN NOT REFINE YOUR TUNE WITHOUT THIS INFORMATION.
Ted.
pnltnc1 is offline   Reply With Quote
Old 03-24-2011, 08:17 AM   #9
2010 Indy Pace Car
NCCOA Ch 1
I called my dealership and a tune does NOT void any warranty, or portions thereof, unless the tune or MODS can be shown to have been the direct cause of a failure. Ex. Last week they had a 2010 in that had a SC installed by an aftermarket, non-GM affiliated shop. The crank pulley was whobbling (bad). It was replaced under warranty even though the car had been modified and tuned without any questions.. Association must be shown between what you have modified and what broke or is giving you problems before a warranty is voided, and only then, partially.
Lots of post on this topic. My 2010 Pace only has 1,500 miles. The SCT that you get from Ted, stores your stock tune so that you can replace it should the dealer need to update your ECM via flash. Then, you just reload your Jannettty tune! No issue!!
SS CEK,
Old 03-24-2011, 05:55 PM   #10
siriusdish
Drives: 2010 Camaro L99
Ted, My Dad wants to get the tune checked for his car b/c of how the plugs where after he gets the TB on,and I have a question? I put the livelink on my Laptop and I seen in a different thread there was a file that has the Banks u want. Where would I load that in livelink? Thank you.
siriusdish is offline   Reply With Quote
Old 03-25-2011, 07:41 AM   #11
JANNETTYRACING
Go here and enter your serial number and you can down load the SCT LiveLink Software from the next page. http://sctflash.com/tsupdates.php?PN...5&GUD=1&GSER=1
Old 03-25-2011, 02:50 PM   #12
siriusdish
I went there and says Ford Programmer?
http://sctflash.com/tsupdates.php?PN...0&GUD=1&GSER=1 Found it.
Old 03-25-2011, 03:00 PM   #13
ddunerider
So-Cal Race team!!
ddunerider's Avatar
Drives: Tahoe LTZ,2010 2SS/M6 Camaro
Send a message via AIM to ddunerider
So if I get one of these tuners...With my Ported TB,BBK intake,Flowmaster AT cat back should i see some good gains ...Like how much will I notice it in the set of my pants..
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!!
ddunerider is offline   Reply With Quote
Old 03-25-2011, 03:16 PM   #14
JANNETTYRACING
I just clicked on it and it says GM Tuner 3400
American Racing Headers for 2010 Camaro yields +32rwhp w/o tune, +50rwhp with tune ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 226 08-09-2013 05:01 PM
Jannetty Racing tune Big Daddy Kane Tuning / Diagnostics -- engine and transmission 5 12-11-2010 07:07 AM
MBRP Catback, AIRAID CAI, and Custom Tune sixty9fordkiller Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 03-21-2010 11:22 PM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 12:57 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 09:10 PM
