04-04-2023, 06:06 PM | #1 |
Drives: 2017 Camaro RS l4 turbo Join Date: Dec 2013
Everyone Lowers their car, but how many have lifted it?
I purchased rear wheel spacers for my 2017 RS 1LT, the only problem is that the rear tire rubs the outer fender slightly when hitting big dips on the road, Anyway.... How many of you have slightly lifted the rear suspension, and how did you do it???
04-04-2023, 06:13 PM | #2 |
uhhh nobody has hopefully lol
but if you wanted to buy some coilovers then you can adjust the height
04-04-2023, 06:24 PM | #3 |
04-04-2023, 06:31 PM | #4 |
you can always throw some airbags or footballs in the back
04-04-2023, 06:34 PM | #5 |
04-04-2023, 11:27 PM | #6 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
04-05-2023, 04:17 AM | #7 |
Why, Why and Why? Buy a 4WD.
04-05-2023, 07:28 AM | #8 |
What size tires did you put on it that you got it to rub? Is the spacer making it rub?
04-05-2023, 09:18 AM | #9 |
Patriot
Drives: 2019 Camaro 1SS 1LE Join Date: Sep 2020
I didn’t lift but I did only lower the front 1.5 so it has that ass up stance and some less trained eyes think I raised the back. Especially when it’s sitting on meatier 315s in the back.
04-05-2023, 09:37 AM | #10 |
#inb4Franputs6"liftwith31"mudders
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
04-05-2023, 09:44 AM | #11 |
Drives: ‘23 SS 1LE Join Date: Nov 2021
Probably better to roll the fender than raise the car, especially since the front is already dropped. However another option would be to look into adding a space to the bump stop. It will ride rougher over large bumps though.
2023 2SS 1LE “Red Hot”
Built 7/14/22 Delivered 8/27/22! |
04-05-2023, 09:47 AM | #12 |
Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
can you post a picture of your wheel fitment? it would be very unusual to add ride height.
04-05-2023, 10:47 AM | #13 |
Like this?
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
04-05-2023, 11:51 AM | #14 |
So here's the problem, the Bilstein idea might be the solution, or just coil overs
lifting rear suspension, rear suspension, suspension |
