02-10-2018, 09:56 AM | #1 |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
Head unit going crazy
Radio screenis going crazy. Keeps scrolling back & forth between page 1 & 2, touch feature wont work. Turned car on & off; no change.
Any ideas? |
02-10-2018, 06:34 PM | #2 |
Try disconnecting battery then re-connecting.
02-12-2018, 07:56 AM | #3 |
Disconnecting the negative terminal on the battery worked. That was just weird how the screen was just sliding back & forth between pages, and it kept it on the lower right (of my 5 favorites) radio station. Even using the steering wheel controls to change stations, it kept going back to that one. And in the background I kept hearing the noise that happens when you touch the screen - it just kept making that noise rapid fire style.
02-12-2018, 11:11 AM | #4 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
There is a fuse in the trunk for cutting power to the mylink head unit. No need to disconnect the battery to everything.
05-19-2018, 01:12 PM | #5 |
Drives: 2016 Camaro RS, 2LT Join Date: Aug 2010
Which fuse is it: F16 - Display, or F55 - Radio Controls (looking at pages 272-273 of manual)?
Update: I pulled F16 and that worked. But snapping the fuse box cover back on was impossible. Last edited by wjmeyer; 05-22-2018 at 03:12 PM. |
05-19-2018, 01:58 PM | #6 |
Drives: 2016 Camaro 2SS Join Date: Apr 2017
I too tried pulling the fuse first..didn't work for me. Disconnecting the negative battery cable worked for me.
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. |
