01-23-2018, 06:55 AM | #1 |
Drives: 2016 2SS Mosaic Black Convertible Join Date: Apr 2017
Convertible - Rear Window Glue Coming Loose
Didn't find this issue in the forum.
My rear window (upper passenger side corner) has come loose creating a gap between the window and the ragtop. This looks to be an issue where the glue has failed. Not sure if it is because of the recently cold weather or some other factor. Has anyone else experienced this, and if so, what is a good fix? I've talked to my dealer and he said the entire top would need to be replaced, but I would think there should be a way just to glue it back. Trying to avoid an expensive fix for what should be a relatively simple one. |
01-23-2018, 07:36 AM | #2 |
Drives: 2016 Z06 coupe Join Date: Dec 2016
Shouldn’t it be covered under warranty?
01-23-2018, 08:17 AM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
I believe I saw a post in the forum a while back that there was a TSB issued for that problem and the fix is to replace the convertible top.
01-23-2018, 03:38 PM | #4 |
01-23-2018, 05:38 PM | #5 | |
Drives: 2016 2SS Convertible Join Date: Oct 2017
So, in late November, the full top was replaced under warranty.
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
01-23-2018, 08:12 PM | #6 |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
Mine is starting to do the same thing. You can see the air going between the glass & top as if it's starting to separate.
02-08-2018, 03:46 AM | #7 |
Those of you that got your tops replaced - Is this what your windows looked like?
02-08-2018, 07:23 AM | #8 |
Drives: Hyper blue 1ss convertible 6 sp Join Date: May 2017
Curious also will have to check mine come spring
02-08-2018, 07:30 AM | #9 |
Drives: Love the one you're with Join Date: Sep 2009
Everytime I start thinking ofa convertible stuff like this pops up. First the mess that was the gen5 cars with convertible tops now this. Guess im back on a wait and see train. Im starting to think that GM should stop trying to do convertibles.
02-08-2018, 07:48 AM | #10 |
I have no complaints about my vert love it. If the top needs replacing due to window, I have no doubt they will fix it. If it needs it like I said freaking love this car no complaints would highly recommend a vert
02-08-2018, 12:28 PM | #11 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
I agree i am sure if mine starts they will fix it under warranty I only have 2k on mine so my warranty will expire well before I hit 36k
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
02-08-2018, 02:29 PM | #12 |
Drives: '16 vert 2LT RS NPP Join Date: Jun 2012
Also 2k only here. I need to check it when the car comes out of hibernation.
02-08-2018, 09:01 PM | #13 |
Drives: 2017 Camaro 2ss convertible Join Date: Jun 2017
Mine was a lot worse, the dealer replaced whole top no charge
02-09-2018, 12:28 AM | #14 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I've got 20K miles here. No problems.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
