10-30-2017, 01:53 PM | #1 |
1LE enthusiast
Drives: 2017 SS 1LE Join Date: Mar 2017
M6 launch bog issue, what exactly is it? I can't get mine to do it...
I have tried to launch with LC using various clutch let up techniques, I have also tried to launch myself...varying the rpm's up to about 3000 or so. I can't get it to do this bog thing some mention...
Is this bog more so when launching at a much higher rpm, or when you are on a tire?
2017 SS 1LE
10-30-2017, 05:44 PM | #2 |
it's a good question. It is hard to put your finger on it. For me it was like the car would start moving then fall over a little, then take off, as observed from those watching.
I think though if I stay out of Competition mode I don't sense it. Even so I have recorded low 1.8s both in Comp Mode, with just TC off, and with all nannies off. Other have done better with slicks. So traction is still a limiting factor.
"Democracy Dies in Darkness" |
10-31-2017, 06:07 AM | #3 | |
1LE enthusiast
2017 SS 1LE
10-31-2017, 06:37 AM | #4 |
Drives: '17 ZL1 Join Date: Jul 2016
It seems to be more of a '17 M6 ZL1 issue.
My '16 SS launched much better than my '17 ZL1. And obviously, the A10 ZL1 guys are doing just fine. |
10-31-2017, 06:40 AM | #5 |
I tried low rpm and up to 4K which I think is the LC limit. But with TC off I think we are on our own.
Now with DRs I am doing around 4K TC off. Depending on track prep that could be a spin or a 1.8-1.9. I will say there is very fine point in the clutch release where you can just punch the throttle to the floor. Too early, you get too much slippage, too late you bog, for me 1 out of 4 times just right. Still on my NT555Rs a low 1.8 might be the best I can do. I also think gearing is the biggest enemy of a good M6 launch.
10-31-2017, 03:42 PM | #6 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
I wish someone would make a set of 4:10's!!! May be a tad much on the autocross track, but I'd still give them a try.
11-01-2017, 09:51 AM | #7 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
With slicks the best 60’ I’ve gotten was a 1.6x, but then I missed a shift. Doh! Otherwise it’s consistent high 1.7x, low 1.8x’s. There’s something in the ECM that’s protecting the driveline. HPTuners is working on getting a table for us to look at.
I’ll let you know what happens with radials and a 2-step next spring.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
11-01-2017, 10:02 AM | #8 |
1LE enthusiast
I dunno, I just tried more launches last night, all nannies off, leaving at like 3000 rpm, it took off quite good, no bog at all. How much higher do I need to launch at to feel this? Or do I need a slick to notice this?
2017 SS 1LE
11-01-2017, 01:21 PM | #9 |
I noticed it once I put slicks on and tried launching above 4K
11-15-2017, 05:19 PM | #10 |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
Some have mentioned that power has something to do with it as it is due to the torque management table that tuners don't have access to yet.
After a certain amount of power almost everyone I know in a fast M6 SS has noticed it. High rpm launch, good grip, car falls on its face real quick and then shoots back to life again.
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol // (purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills) // 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap // |
11-15-2017, 10:11 PM | #11 | |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
11-26-2017, 07:21 AM | #12 |
Drives: 2016 2SS Join Date: Jul 2016
I have been looking over Fraxum's logs lately and it is there plain as day. The car basically shuts down and fights back. He gets to WOT about 1 mph in and then the throttle kicks down to about 20%, timing dips out and so does the fuel. It is there for a good .7 or so and then everything comes back in. It looks like he pedaled it to stop spin but he is dead hooked. On some of his logs it comes back in again while in 1st still so he gets double nailed. I am doing my best to work through it but I haven't figured it out yet.
From talking with other's there is a clutch protection tq management deal we can't get to. I am sure it is much more pronounced in the ZL1's due to the power being made stock. So as you mod the SS's or start launching them harder you see it much more. I wish I had a car in front of me at the track to test some stuff to see if we can get around it.
2016 2SS. H/C SBE 1.37 60ft, 6.36@109.49, 9.97@136+. Nuff Said.
11-26-2017, 03:48 PM | #13 | |
11-27-2017, 07:38 AM | #14 |
Drives: 2011 2SS/RS & 2017 1SS Join Date: Apr 2011
Ryan Stevens (GPI) has figured out how to get rid of the bogging issue....it worked for Zach (KyWildcats) - he has no more bogging of the line and can rev past 5K RPM. 11.26 @120MPH Bolt On car best pass.
Think Zach launches around 6K or so....
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE Built/Tuned by Me 2017 Chevrolet Camaro 1SS Auto 9.29 @144.57mph ALL MOTOR SBE #TEAMGPI Gwatney Performance Innovation Last edited by bhillakaiceberg; 11-27-2017 at 04:43 PM. |
Thread Tools | |
