01-29-2021, 08:02 AM | #1 |
Drives: 2014 camaro SS Join Date: Jan 2019
jack point
in the past I would jack the whole rear of the car by placing the floor jack plate under the diff and lifting. now that we have IRS, is there a safe place to lift from?
01-29-2021, 09:38 AM | #2 |
I was told it is best to lift the rear from the back diff mount and flange.
Just a wood block on the jack and place it under the mount point for the diff furthest to the back. The two flanges on the mount flare out to the sides and make a good contact point. |
01-29-2021, 10:08 AM | #3 |
USA-1
Diff, yep.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
01-29-2021, 10:10 AM | #4 |
Drives: 2015 Z/22 Join Date: Aug 2015
I've jacked up the rear via the diff many times with no issues or braking of anything. Use the rear most part (the mount) of the diff, where it's flat and mounts to the subframe, not the casing itself.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
01-29-2021, 11:07 AM | #5 |
Instagram: Sangstah
I use the rear diff most times at the rear most part.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
01-29-2021, 12:57 PM | #6 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
I put these on my car and use the regular jack points most of the time.
01-29-2021, 01:45 PM | #7 |
I really need to get a pair but always spend the money on something else.
01-29-2021, 01:49 PM | #8 | |
Drives: 2014 ZL1 Join Date: Jun 2009
I have a set from ZL1 Addons and they are worth every penny.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
01-30-2021, 07:47 AM | #9 |
Drives: 2011 VR SS Vert Join Date: Aug 2015
ditto
Had to do a little trimming because extra convertible bracing interferes with the regular cutout location in the lower plastic
