01-23-2021, 02:13 AM | #1 |
Drives: 2011 Camaro 2SS RS Convertible Join Date: Jul 2018
Foglights AND DRL on 2SS
Hi Guys,
is there a possibility to retrofit the original light switch with fog light option to use these lamps? Is the necessary wiring harness already available? I would like to be able to use both functions (daytime running lights and fog lights). I have a 2SS convertible from 2011. https://store.ijdmtoy.com/products/c...aylight-70-911 Greetings from Germany |
01-23-2021, 05:19 AM | #2 |
There is a drl harness they sell that’s about $15-20 that just plugs in and it makes your fog lights and headlights to run all the time.
01-23-2021, 08:46 AM | #3 |
Drives: 2011 VR SS Vert Join Date: Aug 2015
gen5diy.com
01-23-2021, 11:25 AM | #4 |
In Germany, it is unfortunately not allowed to always run the fog lights with the head lights. They have to be switchable and I would like to use the original switch for that.
01-23-2021, 11:45 AM | #5 |
Wow that’s crazy never figured that would be a law.
01-23-2021, 01:18 PM | #6 |
It don’t come easy.
Here in the states, I believe you can’t run the fogs with high beams.
01-26-2021, 01:51 PM | #7 |
Evil Genius of Chevrolet
I took apart my switch and took the tension off the big spring inside. Now my lights only go on when I want them to. By doing this it allowed me to use the light bars in the headlights as my drl's. So I can have my drl's on with low or high beams.
02-05-2021, 03:15 PM | #8 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
I have the patch harness and have them on all the time. I have not had and issue in IA, MN, MO, KS, NE, SD
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
