04-11-2020, 03:58 PM | #1 |
Drives: 2011 2SS Black w/Orange Stripes Join Date: Aug 2010
Towels Choice?
What drying towels and polishing do you like and use?
04-11-2020, 04:18 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I've tried many different ones, these are my favorite.
603 h.p. 495 ft lbs tq. |
04-11-2020, 06:38 PM | #3 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
By far the best drying towel I’ve ever used and I have tried tons of them.
04-11-2020, 07:37 PM | #4 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
Try the Rag Company.com. Their prices cannot be beat. Top quality too.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
04-11-2020, 07:43 PM | #5 |
I have tried lots of both.
Best Drying Towel Carpro DHydrate. Why? This towel is designed to just glide across the surface with no pressure. Removes all water in one pass. No streaks. Has one side for paint, one for glass. No friction from towel as you drag it. Extremely durable. Fibers do not pull out if drawn across badges or edges. Maintains absorbency wash after wash. Also very light and easy to use. Best Polishing Towel Microfiber Madness Crazy Pile. Why? A softer towel does not exist. This towel will remove whatever wax, sealant, or polish you are using with ease, and keep removing it long after other towels are loaded up. The most perfect towel made. You could beat your paint with this towel and not scratch the surface.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
04-11-2020, 10:16 PM | #6 |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
Leaf blower!
04-12-2020, 07:30 AM | #7 |
I do this as well, to remove water from the lug holes on the wheels and to get the water out of all cracks and crevices. Then I hit it with some detail spray and a drying towel.
04-12-2020, 11:49 PM | #8 |
04-13-2020, 05:11 AM | #9 |
Drives: 2012 1LT Join Date: Nov 2015
To dry:
Master Blaster Revolution, or Adam's Air Cannon (Warm Filtered Air that a Leaf Blower doesn't have). Follow up with Adam's Waterless Wash or new CS3 using one of his Mini Ultra Plush Drying Towels or Waterless Drying Towels. To Polish: Adam's Single Soft Premium Microfiber Towels. Which ever microfiber towels you decide to go with make sure they are made in South Korea, not China, and they don't have tags sewn onto them.
04-14-2020, 07:15 PM | #10 | |
A pooling rinse is the best thing you can do prior to drying your car after washing.
Removes 80-90% of the water, leaving very little to dry.
04-15-2020, 05:18 AM | #11 |
A Metrovac Master Blaster or Adam's Air Cannon used on a vehicle with a nice LSP is even better than a pooling rinse!
http://youtu.be/5g_n3E97Brc http://youtu.be/95prWM1hgXo
04-15-2020, 02:43 PM | #12 |
A metro vac costs $280, the adams is $300......A gallon of water from my hose costs a penny and a half.
1 minute to do the pooling rinse, 2 minutes to drag a DHydrate towel to get the rest of the water. 10 minutes with a cordless blower (Black & Decker) I paid $30 for, to blow all the water out of the areas where a towel will not get to, along with the wheels/tires. With the $270 left over I can buy all the towels, wash mitts, shampoo, and LSP I need for years.
04-15-2020, 03:29 PM | #13 |
Drives: Camaro 1LE Join Date: May 2018
Our daily rides get washed at the car wash and then drove home. A nice 10 minute commute back to the house and 99% of the water is gone. Then I'll hit them with a damp synthetic chamios. I use a older one for the door jams. My 1Le has only been washed twice since I bought it. I use meguiars detail spray and i detail it all up with Member's Mark Microfiber Towels (36 cloths per package) from Sam's. We've used these for years now including on our race cars with very good results. At one point when we were racing, I think we had something like 40-50 packs on hand at all times.
04-15-2020, 07:14 PM | #14 |
Tri-County Camaro SWFL
Best drying towel - Adam's ultra plush.
Best polish towel - the rag company Everest 800gsm or 1100gsm
