02-14-2020, 01:00 AM | #1 |
Drives: '10 Camaro SS Join Date: May 2019
L99 Cylinder 5 misfire problem, please help
Hi. I have an issue. When i drive 3-4 k rpm, CEL light came on for 5-6 second then disappear. The pending code was p0300 random misfire and p0305 cylinder 5 misfire. Replaced spark plug, spark plug wires. Nothing changed. And only first start in the morning, the engine die in 1-2 second after start. But second try it totaly normal. Normal drive is totaly normal. I have a cold air intake with new maf sensor, catless x pipe with long tube headers, custom engine and trans tune.
There is the code: https://i.hizliresim.com/7QmB7P.png |
02-14-2020, 01:46 AM | #2 |
Drives: 2015 2SS A6 Commemorative Edition Join Date: Nov 2019
Have you tried swapping coils to see if the cylinder # changed?
02-14-2020, 02:57 AM | #3 |
02-14-2020, 07:16 AM | #4 |
I would check fuel pressure you might have a pump dying. Start then stall the fuel might be bleeding back when the car is off and not getting good prime on first start or low fuel pressure. If it is a random misfire that also leads me towards a fuel issue or vacuum leak
02-15-2020, 04:47 AM | #5 |
https://i.hizliresim.com/7QmJJN.png
Here is my fuel pressure. It contains wide open throtthle. Max 450 kpa, min 366 kpa. In ignition on 546 kpa. Especially in cold weather like 0 C, car starting but immediatly die. I tried 2-3 times and it run. Last edited by imponte; 02-15-2020 at 05:38 AM. |
02-15-2020, 05:33 AM | #6 |
I have long tube headers. The o2 sensor can cause that issue? Maybe they are melting? Or heated issue?
02-15-2020, 07:02 AM | #7 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
I would suspect the maf sensor if you replaced it and the intake AFTER the car was tuned. The maf is extremely sensitive in these cars.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq Last edited by 3rdgen3; 02-15-2020 at 07:24 AM. |
02-15-2020, 07:39 AM | #8 | |
Today i bring the car to a local shop. Read dtc, i have a new code. P1153.. and p0300. P1153 is o2 sensor. Im gonna replace my o2 sensors before the cat. Maybe the all issue is that simple. I drove 50-60 miles and no issue. And of course i changed the coil 5 to 3. |
02-20-2020, 05:08 AM | #9 |
Update !
My tuner edit his tune and all problems gone. So far so good.. Thank you every one!! |
