Old 10-05-2019, 05:49 PM   #1
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Dyno over 500rwhp cam only
Did 540rwhp /425rwtq uncorrected
519rwhp / 407rwtq corrected, HP were still climbing at 7300.
Cam is holding on but clearly I need something bigger.
91oct.
On a dyno mustang but it was calibrated to dynojet results.
TSP 231 236, Tick perf PR/ 660 springs, SW headers 2" & HFC, NPP, Goertz1 custom intake to fit hood, U/D pulley, 18lbs spec clutch, vararam Cai, Pat G tune.
I trapped 123.6 on a 2.0 0-60ft 4000 RW.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 10-05-2019, 05:50 PM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
nice. whats ur combo.
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 10-05-2019, 06:00 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I too am cam shopping. Trying to decide between a cam motion llsr and a btr spec hyd cam....
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 10-05-2019, 06:05 PM   #4
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
With an LOD I'd go llsr.. I think my similar intake is easily good to 7800-8000
13' 1LE
Old 10-05-2019, 07:37 PM   #5
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Got slips, Whammo?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 10-05-2019, 07:39 PM   #6
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Originally Posted by Chris49066SS View Post
Got slips, Whammo?
You can check for my post in the 1/4 mile list for my best ET 11.90@122. did 11.99@123.6 that day. Couldn't do better than 2.0 0-60ft.
13' 1LE
Old 10-05-2019, 07:52 PM   #7
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Is that 60 foot with the toyos?
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 10-05-2019, 08:04 PM   #8
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Yes. Only the slick equipped car did well that day. Toyo DR just aren't cutting it. Gonna go with Mickey next year.
13' 1LE
Old 10-06-2019, 10:04 AM   #9
Chris49066SS
Drives: 2010 SS L99
Solid trap speed! It will definitely be interesting to see how the stickier tires help you
Old 10-06-2019, 10:11 AM   #10
Umbriel
Drives: 2016 Camaro SS
I went 11.2 @ 122 mph cam only with a 1.5 60 foot. 492 rwhp Dyno
Sent from my SM-G955U using Tapatalk
Umbriel is offline   Reply With Quote
Old 10-06-2019, 10:19 AM   #11
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
I wanna see that intake! Solid cam only power right there. Hoping to go some 11.5x times on my next trip out. It was on a pass to easily do it last time I was out, before my night was cut short by coolant all over the track.
I think you should go some mid-low 11's on that kind of power with a good tire. Those light weight clutch setups are no joke and really seem to make HP and MPH good!
Old 10-06-2019, 12:26 PM   #12
Chris49066SS
Drives: 2010 SS L99
Thats what I am shooting for next month. 11.32@120mph right now but I think with cooler temps and better DA 11.2 should happen. 11.1 is asking a bit much
Old 10-06-2019, 12:44 PM   #13
Umbriel
I feel like with better weather I could have maybe gotten an 11.1 but don't think it would get any quicker at 122 mph. Now I've got a forged 416 stroker, GPI boost cam, fuel system, F1-A Procharger, Procharger intake, DSS driveshaft GeForce 1400 HP axles. Hoping to go mid to low 9s with it.
Old 10-06-2019, 01:42 PM   #14
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Well I was at the track and rain again. I think I got cancelled like half the time I went to a track :(
That's a solid setup!! I'm hoping for 11.6 until I buy Mickeys
Thanks! DA was good in the 800 but not hero DA.
13' 1LE
