05-25-2017, 12:03 AM | #1 |
Drives: Black L99 2SS/RS Join Date: Mar 2014
Cam check in thread
Over the past I'd say... 24 months, there have been a pretty large number of cams popping up in this section with overall successful installs.
How are they treating you now? Anyone got anything to report? I've read where a member said he swapped his springs out every 10,000 miles or so. So far so good? Any trouble, close calls, failures, etc? |
05-25-2017, 12:36 AM | #2 |
Stage III BTR and springs. About 27k miles on it.
05-25-2017, 01:47 PM | #3 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
BTR Stage 4 and .660 BTR springs, installed June 2015. 20k on it and absolutely mint still!
Im thinking about moving to a bigger/better cam later this year.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
05-25-2017, 03:12 PM | #4 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Lingenfelter GT1-1 (used), Lingenfelter beehive springs.
5K no probems. Well, I had one problem according to some guy in a parking lot. He told my wife as she was walking back to the car to have it looked at cause something is wrong, it shouldn't sound like that haha. |
05-25-2017, 05:43 PM | #5 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
Cam Motion custom grind , a little over 8k, so far everything is good.
05-25-2017, 06:59 PM | #6 |
TSP 227/235 and their provided .675 dual spring kit. 3 years and 25k miles no issues. (Knock on wood)
05-26-2017, 02:53 AM | #7 |
Drives: Camaro and Sierra Join Date: Jul 2012
Tsp vvt2 with 15k and then ss4 with 4K. Car is not a daily so doesn't see a ton of miles
05-26-2017, 06:29 AM | #8 |
Drives: 2012 2SS/RS LS3 Join Date: May 2012
Cam Motion 228/236 with TEA dual springs for 8k so far. Motor runs smooth with zero issues to date.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA Kooks 1-7/8" LTs w/ Cats Roto-Fab, Bo White TB, Borla Touring Catback 3.91 1LE Gears, MGW Tuned by Pat G |
05-26-2017, 09:20 AM | #9 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
GPI VVT SS3, I guess I have 10K on it, daily driven, runs 10s.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
05-26-2017, 09:38 AM | #10 | |
05-26-2017, 03:29 PM | #11 |
Moonshiner
Drives: Holden SS-V L77 flex fuel Join Date: May 2012
EPS custom yet typical VVT 2 spec (mid 20's early 30's) with AFM. So large base circle with moderate lift 0.555" leveraged via rockers. Low stress setup, daily driven 100k on it, runs 11s with a wagon body.
Idles 550 smooth as a baby's bum.
Compression is King.
Naturally as-pirated, all-motor, all alcohol. |
05-26-2017, 07:08 PM | #12 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
BTR Nightfury; 233/242 .629"/.629" 113+3, w/.660 springs.
It's only been three weeks but running strong
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
05-27-2017, 09:08 AM | #13 |
old school chevy rodder
Cammotion stage three nice and mild for now going over 10k, had a tsp 235 239 too sold it with 10k on it prestine from last engine..I break in a cam with br30 not stupidity and some guys thought train that spread a myth because its does not fail immediately like a flat tappet that falls on its face. These springs most likely should be swapped out at 25k on cams , that's to keep them fresh enough to not be worn the F out, some mild cam with beehives..well they are more likely to last longer and not fail on some high rev valve float or worse. Most people are smart enough to go with 8620 cores now as hey ....who knows if they do a break in which racers live on....
05-28-2017, 11:53 PM | #14 | |
Drives: 13 1LE Join Date: Jul 2013
sub .60 lift cam, no racing, quality valve spring, no extra maintenance needed, good to go for the long haul. Like comparing a boosted car at 8 PSI, and one at 15, even if both have the same power plant and turbine. Different maintenance, different game, otherwise, different end game. Different games at play here. |
