02-20-2020, 07:43 AM | #29 |
I find it hard to believe there’s not a better intake than a factory piece that’s been ported. Typically factory stuff isn’t that great, don’t get me wrong it is what it is and I have a GPI intake to install. An the FAST isn’t worth it for the literal few ponies it brings to the table vs what it cost.
Orange Krush II
02-20-2020, 08:59 AM | #30 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Yes, we are used to factory stuff falling short. But Chevy did hit a home run with the LS3. I came from Fords, stock LS3 cylinder heads flow better than my $3000 dollar heads/valve train setup on my turbo 351W. Changing out the intake isn't worth it until you hit the 1000hp range FI or are doing an all out NA set up. Honest high end shops will talk you out of most after market intakes for 80-90% of us street car guys. That $1000 for a fast could be better spent elsewhere.
I'm seriously contemplating a new forged short block and building my own single turbo system and if I don't go to LS7 style heads/intake would keep the stock LS3 intake.
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
02-24-2020, 12:23 PM | #31 |
Dan
Looking forward to 3rdgen3 results with the LS3 BTR...
Dan
03-06-2020, 05:39 PM | #32 |
Also, looking forward to the results, and pics when installed.. Good luck sir !!
03-06-2020, 07:57 PM | #33 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
I've had a bit of a set-back guys, my new pistons were put on back order from Wiseco basically at the same time that I ordered them basically at the same time as the intake.
This is the state my car is in at the moment but once the pistons are here I'll reassemble and install with the BTR intake at the same time. I also ordered a new turbo, its a new gen custom design from Viren at VS racing, it's 85/96 1.25ar. Sent from my LG-H933 using Tapatalk
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
03-07-2020, 07:50 AM | #34 |
Wow that sucks that the pistons were back ordered! It's always nice to have everything on hand and do the job job all at once. Good luck sir, keep us posted.
10-12-2020, 10:21 PM | #35 |
Drives: 2010 2SS/RS Join Date: May 2010
I wonder how much the heatsoak factor is with the casting of the BTR3 vs my Holley Sniper EFI I have especially with boost. On the Gwatney intake shootout my Sniper was as good as the LOD to 7200rpm.
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! Last edited by ZX1truth; 10-12-2020 at 10:42 PM. |
10-13-2020, 12:01 PM | #36 |
Drives: 14 ss camaro summit white Join Date: Oct 2014
I remember back in the day they used to give a big speech on the what was it the weind intake about heat soak etc ... wonder if times changed
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe 2019 sierra duramax 2500 all terrain x 2001 trans am Lsx 408 ci rebuild in progress(dead project) 1967 camaro Sbc 327. |
10-13-2020, 03:36 PM | #37 |
My LOD gets kinda warm after driving it hard for a bit and you stop, but if you touch it right away after driving, you can lay your hand on it and still feels cool to the touch. But when she sits for a while, like at a car show with the hood up, it cools down pretty quickly. Also when we tuned my LOD, we pulled it out to 7500 and it still wanted to go for more, but we stopped there as it wasn't necessary to pull it higher. Hope OP's build is still going on..Waiting patiently. lol
10-15-2020, 06:31 PM | #38 |
Dan
Where is the update on the BTR intake?
Dan
10-16-2020, 06:37 AM | #39 | |||
Bigger turbo?
2011 Camaro SS---SOLD
10-30-2020, 04:05 PM | #40 |
Dan
Any news??
Dan
10-30-2020, 04:08 PM | #41 |
We are all still waiting, patiently. lol.
12-06-2020, 05:49 PM | #42 |
Bump, any more news on this build and intake??
