12-31-2019, 02:38 PM | #1 |
Some advice from those who have been there
Hi guys. I have my 2015 L99 Camaro SS torn down to the short block. I placed my order with GPI yesterday and ordered the max performance kit. Upgraded a few parts. So i already have longtubes and corsa exhaust. Also a cai. Anything else need changed or should be changed while i have the motor apart? Im doing a converter and 391 rear as well. Just trying to make sure i dont end up kicking myself for not changing something i should have when it was all easy to get to. Thanks
12-31-2019, 04:05 PM | #2 |
What intake manifold did you go with? If it’s aftermarket I would get a throttle body that matches the inlet of the intake manifold. Fast will be 102mm and MSD is 103mm
2010 2SS/RS
12-31-2019, 04:12 PM | #3 | |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
If youre looking for "max" HP you'll also need to order a crank scrapper and an under drive pulley along with an electric water pump. Good luck with the build! Sent from my LG-H933 using Tapatalk
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
12-31-2019, 04:42 PM | #4 |
12-31-2019, 04:44 PM | #5 | |
12-31-2019, 04:46 PM | #6 | |
12-31-2019, 05:05 PM | #7 | |
10-bolt Destroyer
12-31-2019, 05:05 PM | #8 | |
Drives: 2010 SS L99 Join Date: Sep 2018
Heres an example; I am at 87k miles, with 11k miles on my cam. I make 483rwhp with an L99 and run the stock chain, but spin it to 7700 RPM. I've had no issues, however, at closer to 100k miles, I will be getting the Katech C5R chain and a new Melling high volume oil pump. My point is that on a lower mileage L99 I would keep the stock oil pump, but definitely replace the chain. Anything 100k and more, I'd just knock them both out. My budget just didn't allow me to do the chain when I had the rest done. And yes, the wedge-style tensioner is a simple one-piece replacement, and is included in GPI's cam kits. Its quite inexpensive too.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 Last edited by Chris49066SS; 12-31-2019 at 05:15 PM. |
12-31-2019, 09:09 PM | #9 |
Drives: 5th Gen L99 Join Date: Nov 2017
I’m not up to date on the “Max performance kit” but make sure the heads have a trunnions upgrade. External oil cooler for the stall may go without saying but, some people don’t.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
12-31-2019, 10:29 PM | #10 | |
If you have the money I would highly recommend an oil pump as well. I installed a Melling HV 10296 in my rebuild. But you have an L99 pump which is already superior to the OEM LS3 pump. How many miles do you have on the shortblock? That should play a role in this as well. If it's low mileage, you L99 pump may be fine. The chain itself is your call really. I have seen a ton of guys running in excess of 460 rwhp running stock chain. Check for excessive slop. I have personally never heard of an LS3/L99 timing chain failure, but I am sure it has happened to someone. But like all these other things we are mentioning, it is a nice thing to replace while you are in there and is fairly cheap to upgrade. All these parts offer a bit of comfort after spending this kind of money. If I could do my LS3 rebuild over again, I probably would have put more money into the lifters. But money was tight and I went with stock LS7 lifters which was ok for me for now since I was just refreshing the engine on the stock cam. In the end it all comes down to your wallet. If you have endless funds then replace everything while you are in there. If money is tight or you are trying to be careful, then prioritize. Think about your mileage and replace/upgrade wear parts. When building a monster engine it is always better to be proactive than reactive.
12-31-2019, 11:21 PM | #11 |
12-31-2019, 11:24 PM | #12 | ||
01-01-2020, 01:44 AM | #13 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Do people reuse the stock pump because the assembly and alignment of the aftermarket one can be done wrong? My shop said stock pump but I could get a melling if I wanted but they didn’t see failures of stock
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
01-01-2020, 02:25 PM | #14 | |
Drives: 13' 1LE Join Date: Apr 2012
The extra oil pressure for all the rpm. LS2 dogbone, better lifters, stock new chain et voila.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
