04-19-2017, 01:38 PM | #15 |
This x infinity. You probably have a bad power/ground connection somewhere under your hood, so I would start there. I replaced a starter because I thought it went bad and was getting heat soaked. Even put heat reflective tape on the starter, starter heat shield, and the wires running to the starter. Turned out to be a ground wire that wasn't grounded properly.
Now the only time I have harder starts than normal is when I get gas... those you can attribute to heat soak. Don't waste your money on a high torque starter. Stock OEM piece is fine, check your grounds.
2010 2SS/RS
04-19-2017, 02:55 PM | #16 | |
Drives: Miss Con Ception Join Date: Aug 2016
Would you please remove my image from your signature, cowboy?
2011 1SS/RS LS3 CGM
04-22-2017, 08:24 PM | #17 | |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Pity a man in familiar places, who yet feels like a stranger.
04-22-2017, 09:12 PM | #18 | |
It's your money, do with it as you please...
2010 2SS/RS
04-23-2017, 09:23 AM | #19 | |
Drives: 2011 Camaro 2SS Manual Join Date: Mar 2015
04-23-2017, 11:14 AM | #20 |
#938 of 1524
Drives: 2013 Hot Wheels Edition Camaro Join Date: Mar 2017
Check all your grounds and put heat shielding around your starter and you should be good to go with the stock unit.
Your original question was looking for opinions on what the best high torque starter is. I've got a 79 chevy k10 truck with a 383 stroker in it. I've got a powermaster master torque starter on it. combined with a good battery and the correct timing, that starter works 10 times better than the stock unit. |
04-24-2017, 09:41 AM | #21 |
There is a large ground wire on the drivers side head, right behind the PS reservoir and there is another large one on the passengers side head that is towards the front as well. There is a block of smaller ground wires on the passenger side head that is near the dipstick tube bolt as well. I messed with the large passenger side ground when I went to install my catch can for the first time. Did not realize what I moved until about a year or more when I was messing with the starter lol
Edit: another thing to check out is how clean the power wire connection is that attaches at the starter. Mine was very corroded which will also contribute to slow starting
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 Last edited by xc_SS/RS; 04-24-2017 at 10:32 AM. |
01-26-2023, 07:03 AM | #22 |
Chevy's "Rumble" Best!
Drives: 2015 ZL1 6 speed Join Date: Feb 2011
I'm just going to add to this thread in case someone stumbles upon it while having problems. The ground wire in the trunk that goes from the battery to the trunk floor is the biggest problem. It's a terrible connection, you need to remove the bolt holding it to the trunk floor and clean or grind the mating surface.
01-26-2023, 12:28 PM | #23 | |
To add to this very old thread, I am also running the Powermaster XS Torque 9509 starter. The thing is a beast
07-18-2023, 01:48 AM | #24 | |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Got a start up video of yours? I'm going to order that bad boy and do it with my new ground cables!
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
