Go Back   CAMARO6 > Marketplace > Members Classifieds > V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment
Old 09-09-2020, 03:48 PM   #1
19Nasty1le
Craig
19Nasty1le's Avatar
Drives: 2019 ZL1 1LE
Canada - WTS: Soler Throttle Body and Throttle Controller
**BRAND NEW**
Ported stock Throttle Body off a 2019 Camaro ZL1 1LE 87mm ported to 91mm for a 6.2L SC LT4 Manual BT Soler Performance.
FEATURES:
• Optimized Active Contours with sonic flow nozzles
• Porting Taper and Upstream Bore with Velocity Stack (Lip & Bore Reduction)
• Greater Discharge Coefficient of Plate/Blade interface
• 16 Ra Microinch, Diamond Polished Surface Finish (Lower Skin Friction)
• Shaftless high-pressure side of the blade for Larger WOT Flow Area (91 mm Effective Bore)
• Self-Cleaning Throat/Flow Gap
• Dome and Thread-locked Screws
• Made from Brand New OEM Parts
BENEFITS:
• Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience
• Linearization and smoothing of the curve for a more predictable response and crisper shifts
• Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning. Warranty safe.
• More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
• Easy Installation (15 Minutes or Less)
Also a Soler Performance Throttle Controller for a 7th Gen Corvette, 6th Gen Camaro or CTS 3
FEATURES:
Five Modes, with a total of 37 possible settings
EC Mode (Economy): Nine settings for improved fuel economy in city/hwy driving.
OE Mode (Orig. Equip.): Same as stock ( One setting).
CF Mode (Comfort): Nine settings for comfortable driving, all slightly more responsive than stock.
SP Mode (Sport): Nine settings for spirited driving, with setting SP.5 giving a quasi-linear response when used with our throttle bodies.
LU Mode (Ludicrous): Nine settings for very aggressive acceleration, for track use only.
Compact LCD Display (2” x 1 .25” x .25” ) with white characters. Aluminum case and buttons.
Fail-safe vehicle specific design.
BENEFITS:
Controls pedal sensitivity, allowing driver to adjust an otherwise widely considered non-linear (slow/spongy) pedal response/map.
Increases the sensation of acceleration/power, very important for driving pleasure in finely tuned sports cars.
Complements performance Throttle Bodies in achieving total throttle control as a system.
Plug-and-play modification.
Warranty safe modification.
Easy installation (15 min, no tools or special skills required).
Asking:
Throttle Body $525CDN
Throttle Controller $150CDN
OBO
** Located in Ontario Canada ���� **
19Nasty1le is offline   Reply With Quote
Old 09-11-2020, 09:19 PM   #2
19Nasty1le
Craig
19Nasty1le's Avatar
Bump
Old 09-16-2020, 10:59 PM   #3
19Nasty1le
Craig
19Nasty1le's Avatar
Bump
Old 09-20-2020, 08:45 PM   #4
19Nasty1le
Craig
19Nasty1le's Avatar
Still up for grabs, BRAND NEW NEVER USED
Old 09-29-2020, 12:35 PM   #5
19Nasty1le
Craig
19Nasty1le's Avatar
Bump
Old 10-04-2020, 01:45 PM   #6
19Nasty1le
Craig
19Nasty1le's Avatar
$600 CDN for the 2
