Roto-Fab
Old 07-13-2019, 04:09 PM   #1
PatrickS
PatrickS's Avatar
Drives: 2011 2LT RS
Pop sound when starting
Hello!
I have a 2011 2LT/RS V6 that occasionally will make a pop/click sound when starting. Usually it will make this sound when it’s been warmed up and started after a short trip to the store.
Any ideas what this might be? Or has anyone heard this before?
Thanks!
PatrickS is offline   Reply With Quote
Old 07-13-2019, 07:11 PM   #2
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
I'm interested in this too... my son's 2011 2LT does this too when warm on occasion. Doesn't seem to cause any problems and I have over 100k miles now so I am not too worried about it though.
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 07-13-2019, 08:30 PM   #3
PatrickS
PatrickS's Avatar
Drives: 2011 2LT RS
Nice to know there is another with this sound. Mine has 24K though...
Old 07-14-2019, 06:48 AM   #4
PowertoLove
Drives: A Sneaky Fast Camaro
Can you hear if it is popping out the exhaust or the intake. I would suspect the VVT phasers either way. Might be dirt or sludge build up on the solenoid's or in them. Doesn't take much. Are you using synthetic oil? Synthetic oil will keep the engine much cleaner in the long run.
PowertoLove is offline   Reply With Quote
Old 07-14-2019, 08:20 AM   #5
PatrickS
PatrickS's Avatar
Drives: 2011 2LT RS
thanks for the suggestion. It’s definitely in the front. It occurs while it is cranking.
I’ve only had the car long enough to change it twice, but I’ve used full synthetic
Thanks!
Old 07-14-2019, 08:23 AM   #6
PatrickS
PatrickS's Avatar
Drives: 2011 2LT RS
I will try to record the sound when it happens and post a link.
