08-05-2022, 10:34 PM | #1 |
Drives: 2016 camaro 1ss 500hp Join Date: Nov 2018
6gen zl1 losing power under acceleration need help ASAP!!
Ever since i started doing remote tuning my car has been losing all power under wot. Also throws a bunch of codes that i will list. Thought it could have been the tune but even when i went back to stock file the problem persisted. Its saying loss communication to chassis control module and invalid data received from ecm/pcm aswell as random misfire. Im so lost because I’ve diagnosed everything that ive seen on the forums. Checked harness by passenger header and no sign of any burnt wires. They have been ziptied a few inches away. Changed new plugs and new wires. Checked all the ground wires i could possibly see and nothing seems to be off. Was informed to check my dsx e85 sensor that i put on myself checked the main connector that i tapped into for the e85 system and everything seems to be fine. Going on about 2 weeks with this issue and im beyond frustrated. The only thing that ive yet to figure out is i just recently heard a sparking sound from under the hood when i was testing the car after i found out one of my new ngk plugs somehow is cracked(not sure if it was from factory or something cracked it). I tried check it out late at night where theres no light but still nothing. Just heard it spark few times and i believe it could be from driver front side of the car. Please point me in the right direction!!!
2018 A10 ZL1 with basic boltons Codes : C0242 U0401 invalid data received from ecm/pcm U042B invalid data received from chassis control module A P0300 random misfire detected P0420 catalyst system efficiency below threshold bank 1 |
08-05-2022, 11:33 PM | #2 |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
So, did you replace the cracked plug? You can scan for misfires to see what cylinder it is. This would be a good place to start.
2002 Corvette Z06 - Black - Sold
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
08-05-2022, 11:42 PM | #3 |
Drives: 2017 Focus RS Join Date: Dec 2021
Ideally should list what changes were made without knowing all the facts hard to give an answer.
2023 ZL1, M6, Shadow Gray
08-06-2022, 08:19 AM | #4 |
08-06-2022, 08:57 AM | #5 |
The mods done to the car? Or the changes made after the issue has happened. In terms of mods done its just dsx flex fuel jlt intake nitrous express lid kooks 2in headers 160 thermostat and thats about it
08-06-2022, 09:48 AM | #6 |
Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
Change your battery and try again.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
08-06-2022, 09:56 AM | #7 |
08-06-2022, 12:11 PM | #8 |
If you flashed the car and it lost communication when flashing that is why you have these codes. Only way to clear them is to remove the battery for at least 30 minutes. You can’t clear these codes with hp tuners.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
chassis control module, help me please, invalid data from ecm/pcm, loss of power |
