08-25-2013, 05:57 PM | #1 |
Drives: C7 / ZL1 / SS / trucsk Join Date: Nov 2009
FACTORY TIE DOWN POINTS ?
Where are the the actual FACTORY tie down points on the ZL1?
Any assistance would be appreciated I don't want to have to strap though the wheels |
08-25-2013, 06:27 PM | #2 |
Drives: 2016 SS Join Date: Jan 2013
Be interesting to know. If I crawled under my car I could remember where I tie it down at. But be nice to know the designed tie down points!
08-25-2013, 07:05 PM | #3 |
DBLCHBY III
Drives: 15 1LE Join Date: Jun 2011
try posting this in the drag race section
08-25-2013, 07:14 PM | #4 |
Drives: rumble bee,2SS 6sp Join Date: May 2009
As a tow driver 95% of the gm cars have them just inside the pinch welds behind the front wheels and infront of the rear tires. Kinda where you would jack a car up...
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not. |
08-25-2013, 08:05 PM | #5 |
Drives: 12 ZL1 & 08 Suzuki Boulevard C50 Join Date: Oct 2011
no factory tie down points. I am installing universal tie downs from RENNLINE since my ZL1 is on a lift I have a found a few places to install and the 66 degree ones do not hang down.
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
08-25-2013, 11:00 PM | #6 | |
08-27-2013, 10:23 AM | #7 |
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1 Join Date: Feb 2012
Here is a pic of the frame tie down locations I use.
The rear locations are easy to find, in front of the tires about in line with the jack pad notches on the side rails. The front locations on a ZL1 take a bit of work. take out about 4 - 5 of the bolts on either side of the belly pan so that it is loose enough to pull down so that you can find the factory hole in the frame rail. Locate the hole on the belly pan, and use a Dremel with a roto cutting tool and route out the hole using the factory frame rail hole as your guide. |
08-27-2013, 10:25 AM | #8 |
Perma Grinning
08-27-2013, 10:28 AM | #9 |
Perma Grinning
Here is a close up of the hole in the front rail with the hole cut in the belly pan.
08-15-2020, 05:25 PM | #10 |
Space Coast Camaros
Drives: 2012 Camaro Vert Join Date: Sep 2011
Anyone know if the back tie down locations can be used on a convertible?
There is a extra bracing bar that is almost over the hole. Dont know if a t hook will still fit. |
08-16-2020, 02:12 PM | #11 |
I use one of these 6 holes, the thickest one. I have to put the straps in before pulling the car in the trailer. I use the LSAs in the rear. I have towed thousands of miles like this. No bounce, no movement in the trailer.
