dave@hennessey
Old 06-09-2016, 09:28 PM   #1
fab410
@fabSSbuild on IG
fab410's Avatar
Drives: 2012 Twin Turbo Super Sport
Buzzing from rear of car & low fuel pressure
Hey guys, I'm trying to pin point an issue and was wondering if anyone has had any similar issues before. I have a Squash Dual Pump set up with Hobbs Switch as well. The car has only put no more than 3-4K miles on it (if that) with the twin pump set up installed. Went to start the car a few days ago (since I hadn't started in over a week with low fuel) and started fine. Went to fill the tank, grab some dinner and everything was still fine. The next day, turned the ignition on and now I have this sound in the video. I also noticed my fuel psi is around 20psi with ignition on, I'm used to seeing around 40-50. I attempted to swap filters and that still didn't resolve the issue. Any feedback would be helpful !
https://vimeo.com/170109832
AGP Twin Turbo, FAST lsxR manifold, ID850's, Squash Return Style Fuel System, ZL1 Bumper/Side Skirts/Hood/Carbon Insert, Havoc Rear Diffuser, PFADT Coilovers/Sway Bars/Adj. Tie Rods/Solid Subframe Bushings/Trailing Arms, Eboost2, SW Retro Chambered 3" Catback, R1 Concept Drilled/Slotted Rotors, 360 Forged Straight 5's, Matte Metallic Purple Wrap, Anvil Carbon Spoiler, Full AAC Lighting, etc
fab410 is offline   Reply With Quote
Old 06-09-2016, 10:01 PM   #2
Unreal
Drives: 2006 Z06
Trouble shoot one pump at a time. Either pump alone should be able to provide enough pressure at idle and low boost. Try swapping the wiring to rule out the main pump dying. The start checking for leaks or issues with the fuel components. Could be a bad regulator, or something came loose with the squash setup.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 06-09-2016, 10:03 PM   #3
fab410
@fabSSbuild on IG
fab410's Avatar
I appreciate it, that's what Andy advised next is swapping the wiring to determine if one is dying.
Old 06-09-2016, 11:33 PM   #4
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
sounds like bad pump. easiest way would be disconnect the ground wire off relay 1 for pump 1 to turn it off and ground the wire normally from the hobbs switch to relay 2 turn on pump 2
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 06-09-2016, 11:41 PM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
How low was the tank, before you filled it up?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 06-10-2016, 08:10 AM   #6
fab410
@fabSSbuild on IG
fab410's Avatar
Thank guys, @1killerSS less than a quarter but not on E
Old 06-10-2016, 09:13 AM   #7
fab410
@fabSSbuild on IG
fab410's Avatar
Ok so disconnected 1 wire from the positive terminal on the battery and buzzing still remained, still 20psi and car started but still makes buzzing noise.
I disconnected that cable and connected the other, no buzzing, 0psi and no start
Old 06-10-2016, 09:19 AM   #8
Unreal
Drives: 2006 Z06
Maybe out of fuel.
Got to remember with aftermarket systems, the gauge may not read the same anymore. Sounds like you were just out of gas. Fill it up and go from there.
And you need to put power direct to the 2nd pump, or jump the hobbs switch, otherwise it won't turn on doing it that way.
Nick
Old 06-10-2016, 09:21 AM   #9
fab410
@fabSSbuild on IG
fab410's Avatar
Problem is, it's almost a full tank right now . The day that I started it with low fuel, i grabbed gas (filled it up) and drove about 10 miles to grab dinner. No issues that night, the next morning is when the problem occurred.
Old 06-10-2016, 09:43 AM   #10
Unreal
Drives: 2006 Z06
May have ran a pump dry, and hurt it. With aftermarket systems, have to be careful about that.
Sounds like a dying pump. Swap which pump is #1 and which is #2.
Nick
