Old 07-20-2016, 07:49 AM   #1
swayf4
Drives: 2015 Camaro ss rs
Vibration issue after 3.91 gear set install
I own a 2015 SS M6 with 8000km. I recently did a 3.91 gear (GM gear) swap which i am very happy with other than the issue i now have. All work was done at the local dealer. The Gear is very quite at any speed but the car develops a vibration when it reach higher speeds starting at 70mph and progressively get worst as speed climbs to a point the cars feels unstable. I don't recall having any vibration at all before the swap. My dealer is suggesting its flat spots in the tires? which i am having a hard time believing.. what would be you thoughts on this? also having a hard time getting the dealer to swap out rims/tire from another car on the lot to confirm or eliminate the tires from the equation. Also just to add i have had a hunter force balance performed already..
swayf4 is offline   Reply With Quote
Old 07-20-2016, 09:00 AM   #2
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
I would take a close look at the driveshaft, center support and couplers.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 07-20-2016, 09:26 AM   #3
flyer08
Drives: 2010 2SS/RS
Sounds like the dealer just doesn't want to deal with it
flyer08 is offline   Reply With Quote
Old 07-20-2016, 09:42 AM   #4
pancherj
"Flat Spots" on tires was much more common with poly glass tires 40 years ago. With modern radials, I have had cars sit in one spot for several years and they still drove fine. Sounds like the dealer is trying to put you off...
pancherj is offline   Reply With Quote
Old 07-20-2016, 12:46 PM   #5
swayf4
Do you think it's possibly a part failure after the install or an issue with the work performed on the reinstall? Trying to decide how i will approach this now.
Old 07-20-2016, 12:51 PM   #6
swayf4
The dealer not wanting to deal with it is what worries me.
Old 07-20-2016, 02:58 PM   #7
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
If it wasn't there before the swap then it's something to do with the install plain and simple. Had my 391s done in may.....no noise or vibration before or after.
rontammy0 is offline   Reply With Quote
