dave@hennessey
Old 10-19-2015, 09:45 AM   #1
pancherj
Drives: 2010 Camaro SS
Transmission Swap - Door and Trunk Lock Issues
I did the TR6060 to 4L80E swap, but I would think this applies to a TH400 or TH350 swap also. My car keeps locking me out! This is with the car running or not running while in Park. I think it might be because I don't have the neutral safety switch hooked up, but I am not 100% sure. It also will not let me pop the trunk if the car is running even if it is in park.
Anyone else have this problem? Any solutions (other than "be more careful"...I'm old and feeble minded!)?
pancherj is offline   Reply With Quote
Old 10-19-2015, 10:14 AM   #2
2010SUMMITSS
2010SUMMITSS's Avatar
Drives: 2010 2SS
I just did a th400 swap in my 2010 from a 6l80 and I have had none of these issues. the only lock problem I have is when I shut the car off it doesn't auto unlock anymore.
2010SUMMITSS is offline   Reply With Quote
Old 10-19-2015, 10:55 AM   #3
pancherj
Is your neutral safety switch hooked up? I think the 6L80 may be different. I believe (not 100% sure) the reverse and NSS are through the BCM and not the engine management computer.
Old 10-19-2015, 02:20 PM   #4
2010SUMMITSS
Drives: 2010 2SS
I do but I just cut the wire to the starter solenoid and ran it to the switch on the shifter. I just ran through some of the threads on here I used and I cant find anything on the wiring for the 6 speed just a bunch of auto wiring stuff.
Old 10-19-2015, 02:30 PM   #5
pancherj
I appreciate the effort! I will make an effort to hook up the neutral safety switch over the winter and see if that cures my problem. If not, I may try to disable the auto-lock all together. I never had this problem on my 1970's nova...
Old 10-19-2015, 02:33 PM   #6
2010SUMMITSS
Drives: 2010 2SS
there is a thread on here where a couple guys did the swap you should pm one of them.
Old 10-19-2015, 02:36 PM   #7
2010SUMMITSS
Drives: 2010 2SS
http://www.camaro5.com/forums/showthread.php?t=335703
here is the link if you didn't find it already
Old 10-20-2015, 09:37 AM   #8
pancherj
Thanks! I have been in contact with DietCoke. He has certainly been a big help. He told me he did not experience any of these door lock issues. I guess I am just special...LOL
Old 10-20-2015, 12:54 PM   #9
williamp78
williamp78's Avatar
Drives: 2011 2ss blk/wht strp
ever figure out the speedo? @pancherj
2011 2ss black/wht stripes
"CAM only"
https://www.instagram.com/w_j_p_boss/?hl=en
williamp78 is offline   Reply With Quote
Old 10-20-2015, 01:53 PM   #10
pancherj
I did! It was just a setting inside the controller. Once I fixed that, it worked fine.
Old 10-20-2015, 08:16 PM   #11
williamp78
williamp78's Avatar
I will definitely hit you up when I get there. My US SHIFT actually came in a few minutes ago.
"CAM only"
Old 10-20-2015, 08:38 PM   #12
pancherj
If you need any help or files to get you started, just let me know. Diet coke sent me some of his files. You just need to adjust them for your throttle voltages and tire diameter and rear gear.
Old 10-20-2015, 09:10 PM   #13
williamp78
williamp78's Avatar
Sweet thanks. All I have left is the trans cooler when it gets here (mine was too big) and the controller install.
"CAM only"
Old 10-21-2015, 08:30 AM   #14
pancherj
PM me an email address and I can send you the files.
