Old 05-09-2017, 10:22 AM   #1
SannerRacing
SannerRacing's Avatar
Drives: 2010 1SS RS IOM
New direction
New 4l80 going in this week from Hughes The m6 is a lot of fun but I want more consistant launches and shifting. Don't get me wrong my buddy's and I have a great time racing each other banging gears,but when a car with less hp with an auto kicks your but! WTH lol This trans is good for 1500 hundred hp so I have some room to grow. Set up with a 3000 stall and designed for the twin turbos going in this winter. I think I've got all my bases covered but you all know how that goes. Any input would be appreciated.
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq
SannerRacing is offline   Reply With Quote
Old 05-09-2017, 11:36 AM   #2
pancherj
Drives: 2010 Camaro SS
The swap is pretty straightforward, but a good bit of work. You will be cutting and banging on the tunnel, trimming some pieces of the 4l80 case, wiring up reverse lights and disabling the clutch interlock, etc. I made it through it, and I'm a dummy! You should have no problems.
pancherj is offline   Reply With Quote
Old 05-09-2017, 11:39 AM   #3
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Daaaang. Glad your going auto cause with those twins coming you would probably have shot to the top of the manual list and that is something I have my sights on .
Cant wait to see how your conversion turns out. It should be great!!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 05-09-2017, 12:17 PM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
That is gonna be so much fun coupled with the twins!!!
More to come.
Black_SS10 is offline   Reply With Quote
Old 05-09-2017, 01:51 PM   #5
bct10985
You doing a 2 step and trans brake? What rear gears. I have a 3600 stall and wish i had went higher
Old 05-09-2017, 06:39 PM   #6
SannerRacing
Well this is what CMS and Hughes came up with. I know the curvature of the flutes or fins in the converter are designed to let the turbos spool up. It's got a Maggie on there now so will see how that works out lol When the turbos go on ill get into all the 2step stuff and the boost leash with the co2 set up. And on and on!
Old 05-26-2017, 08:16 PM   #7
SannerRacing
Missed the gears question there 3:89s close to what your running.
Old 05-26-2017, 08:24 PM   #8
SannerRacing
I'm letting CMS put it in,after r&r my M6 4 or 5 times I've had enough fun! And yes they did some trimming and it came out great. Can't remember who told me I could use the drive shaft safety hoop for the trans mount but thanks.
