04-14-2020, 02:34 AM | #1 |
Drives: 2010 Camaro SS Join Date: Apr 2020
Help with power estimate please 😊
Hi guys
I have just purchased an import from the states, Until I get to a dyno, im sure you guru’s on here will have some good estimates for me please, power and torque.. 2010 Camaro SS, 6spM ls3 TVS 2300 with 3.2 pulley running 12psi Cam (unkown specs, would say street blower cam) CAI Long tube headers and full magnaflow 3” exhaust ZR1 dual fuel pumps Tuned on 98 octane. Thanks in advance. |
04-14-2020, 04:55 AM | #2 |
Hey Rochie, I run similar through an auto and have 600hp atw so I would guess 600-650hp atw.
04-14-2020, 06:08 AM | #3 |
If it has a blower cam it should be on the low end 625. It depends on the tune as well. If it's a good blower cam and good tune I'd say you could be around 675ish
04-14-2020, 11:50 AM | #4 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
Is the 98 octane fuel racing fuel. Regular gas station only has 93 octane.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
04-14-2020, 11:55 AM | #5 | |
Must be nice
04-14-2020, 12:18 PM | #6 |
Started#gottalovethatblue
If I was to take a guess, not knowing anything about the cam or pulley size, I'd say north of 600rwhp.
04-14-2020, 12:19 PM | #7 |
Outside the U.S they use a different rating for octane as well. 98 octane RON is equal to a lesser octane rating in the states which use a PON which is an average between RON and MON so 98 RON would equal to 93 octane in the states.
04-14-2020, 12:39 PM | #8 |
Drives: 2010 Camaro SS Join Date: Oct 2013
I have a similar setup running a 3.4 pulley at about 9 psi. On a Dynojet it is 650 rwhp whereas on a Mustang Dyno it came in just shy of 620 rwhp.
Depending on the cam yours should do better.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
04-14-2020, 05:30 PM | #9 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
I estimate you need to keep some extra rear tires on hand!
04-15-2020, 02:11 AM | #10 |
Thanks all, knew there would be plenty of experience in this group.
Yea it certainly feels like that sort of power, has 315 pilot sports on the back and still struggling for grip right thru 3rd.. 👍 |
04-15-2020, 04:42 AM | #11 |
Drives: BMW 7 Series 2020 Join Date: Apr 2020
BMW
Whipple 2.9 CAI ID1050x injectors JMS BAP JRE Rough Idle blower cam BTR .660 springs CHE trunnion unit 1 7/8 Speed Engineering long cylinders 2.5 feline back borla atak ZL1 siphon JRE stream control module JRE scoop 1.5" bringing down springs BMR trailing arms and toe joins WHP TBD i want to see you something: www.gamingzip.com
more info is here: https://www.gamingkite.com/ |
04-15-2020, 09:27 AM | #12 | |
Drives: 2021 Camaro SS Convertible Join Date: Apr 2016
2015 SS2/RS, SCT Tune (Dynosteve), Vitesse Throttle Controller, Vararam VR-DRX CAI, Vararam Power Wedge TBS, Granatelli Performance MAF |
04-16-2020, 06:18 PM | #13 |
Thanks for all the feedback.
The previous owner wasnt sure about the cam, i only assume it has some kond of street cam because of how it drives (ive had other LS cars). Could you guys checkout these vids and let me know if you think it has got a cam or this is just how they idle factory please? Cheers https://youtu.be/9lDBtIrOgxM - cold start https://youtu.be/M7Cv3Nbg7R0 - idle |
04-16-2020, 06:28 PM | #14 |
Well, here's the thing. You can put a decent cam in a car and still have a pretty smooth so there's no real way to tell. It's obvious when you put a cam in more with valve overlap because that's when you get the chop chop. If you want to know you can pull the valve covers and with a dial indicator measure the lift easily. Can figure the duration too but you'd need a degree indicator to measure new a little harder.
