09-08-2022, 07:44 PM | #1 |
Drives: 2017 Camaro 1LE Join Date: Nov 2021
RT660 track pressures?
Did some searching, wasn’t able to come up with anything particularly definitive. I have 2017 1LE and just went to a square 305 setup on 10.5 x 19 Apex wheels and they are wearing RT660 tires. I am headed to Watkins next week and wanted to see if anyone had a good starting place for hot pressures on a road course.
Thanks! |
09-08-2022, 10:11 PM | #2 |
Shadow Gray '19 ZLE M6
I don't know those tires in particular, but with most street tires, you want to target 36-ish psi hot. You start lower since the psi will rise as you get heat into the tires. I'd probably try going out at 30 psi first session of the day and bleed off as necessary throughout the day.
Maybe someone who knows the characteristics of the RT660 will chime in. Edit: There is also a dedicated road course subforum
09-09-2022, 01:58 AM | #3 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
09-09-2022, 05:24 AM | #4 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
^^ Yes, this is spot on.
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
09-09-2022, 07:38 AM | #5 | |
Obviously tires can vary not sure what the 660 would require.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
09-09-2022, 09:02 AM | #6 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
660s like pressure. I just ran at Sebring last weekend and with 85-93F ambient, started them at 29psi. They came up to 36psi by the end of the session.
I start the SC3's lower, 27-28psi, depending on ambient.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
09-09-2022, 10:45 AM | #7 |
BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
I’m always starting out at around 26psi on the SC3,s and then keep close as can to 32 from there. Tires are wearing nicely.
2021 ZL1 1LE
Auto |
09-09-2022, 11:12 AM | #8 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I run 32/28 for autox but this only works with a stiffer front bar and a lot of camber. With a stock setup you'd want a good bit more pressure, I'd agree with somewhere around 35 hot.
RT660 are really autox/TT tires. They warm up super fast, like just a few corners, and are very grippy but will fall off rapidly at higher temps. I was just at High Plains in CO and a friend with an M3 was not having a great time with them running 25 min sessions, although temps were in the 90's. IMO it's really hard to beat the OEM tires unless you want to go with the SC3R or some other ~100 tw R comp tire. My SC3s were excellent and maintained good grip even towards the end of a 25 min session at 95 degrees.
