AWE Tuning
Old 03-28-2018, 09:47 PM   #43
baron95
2018 1LE, NASA Instructor
baron95's Avatar
Drives: 2018 Camaro SS 1LE
I can't wait to hit the track with my 1LE. But I doubt I'll be faster in it than in the C7 Z51.
On the other hand I traded out of the 2015 C7 Z51 into the 2018 SS 1LE for even money. That is worth a few tens on the track
baron95 is offline   Reply With Quote
Old 03-29-2018, 12:43 AM   #44
TrackClub
TrackClub's Avatar
Drives: 2020 SS 1LE (previous: 2017 SS 1LE)
Ford is cheap and their offers not very serious a la original GT350 missing the coolers too. But very surprised about the PP2 not having coolers. Ridiculous imo. Agree that 1le is a real deal and nicely packaged too.Other than a low grade stereo...but i could not care less as i always listen to LT1 music anyway
TrackClub is offline   Reply With Quote
Old 03-29-2018, 12:44 AM   #45
TrackClub
TrackClub's Avatar
I think you will be pleasantly surprised....
Old 04-06-2018, 10:10 AM   #46
mdbennes
mdbennes's Avatar
Drives: '18 Silver SS 1LE
I've had her for two weeks now, and its a great car! What do you all suggest for a good intake on these?
Retired Air Force (2014)
2018 Silver SS 1LE
Past Rides
2000 Corvette FRC
2000 Corvette Coupe
2002 Corvette ZO6
2005 Corvette Coupe
2016 Corvette Stingray
mdbennes is offline   Reply With Quote
Old 04-06-2018, 10:35 AM   #47
TrackClub
TrackClub's Avatar
Something wrong with stock intake?
Old 04-06-2018, 10:46 AM   #48
nasbagoat
Drives: 17 SW 1LE
GM w/ the tune if you must, but really no intake is worth the money.
nasbagoat is offline   Reply With Quote
Old 04-06-2018, 12:33 PM   #49
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
What he said
Stock paper filter inside the stock airbox has proven to work well. Any upgrade with some sort of aftermarket "intake kit" is going to provide negligible usable power gains in the ideal scenario.
For considerable power gains across the RPM range, it is either investing a lot of $$ on internals keeping the motor in its N/A state and having a marginally streetable car with a max usable power of ~ 550-570 crank on 93 or opt for a FI power adder in the form of a Centri (I.E. ATI, Vortec, Etc) or PD (Maggie, Whipple, Eaton-LT4, Edelbrock-EForce, Etc.) and look at a ~ 700 crank HP figure with proper internal forgings (Pistons to the very least) and upgraded fueling, I.E. LT4 LPS and HPS + Injectors.
Of course a proper tune plays a crucial role in the overall success rate
Eldi Z is offline   Reply With Quote
Old 04-06-2018, 04:26 PM   #50
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
Originally Posted by TrackClub View Post
Congrats to the OP! I too came from a Vette and haven't regretted it for a second.
Baron - my car's suspension feel was subliminal even with factory alignment. So I'd suggest something is not quite right if you're detecting rear end moving around.
Check that everything is buttoned down right. From your description it sure sounds like something might be loose back there? F sway coming loose is a fairly common issue but evident by a "clunking" noise. Perhaps something else is the culprit on your car? In any case that's odd vs normal from what you're describing.
Cheers!
I also get a weird feeling when accelerating over rough pavement/bumps. It kinda feels like the rear subframe rubber-bands a bit. I had a similar feeling in my old E82 135i, which is known to have too-soft rear subframe bushings, especially with a coilover setup. Maybe that's what he is describing?
R3ctivision is offline   Reply With Quote
Old 04-07-2018, 10:04 AM   #51
TrackClub
TrackClub's Avatar
No idea. But his factory alignment was all messed up pretty good. Assuming yours is perfect it could be TC and or elsd hunting for traction while the rear is moving over the bumps. Who knows. I have zero complaints but i am gentle when on rough roads.
Old 04-08-2018, 05:18 PM   #52
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
Check you tube. The craddle bushings do deflect a lot under load. There are a few videos showing the movement.
Pollock is offline   Reply With Quote
Old 04-08-2018, 07:59 PM   #53
baron95
baron95's Avatar
Things definitely got better after I got the alignment and programmed the driving mode to my liking. I know leave it in Sport (since track reverts to Tour at shutdown), with suspension on Tour (bad roads here) and steering sport and exhaust in Track (loud).
After start, I double click traction control button to put it in Competitive Mode. That is the only thing I have the patience to do on every start.
With this set up launch and handling over imperfect pavement is a lot better, and, of course, you can have a lot more before the nannies try to help (which they suck at).
I still feel the back is a lot less settled than the C7 Z51 - the car will wiggle left to right (in a floaty slow manner, nothing scary, but weird) on full acceleration all the way to near 80MPH. And on turns I still feel the rear first take a set, then hold the car to carve the turn - it is a definite two step process vs a single one in the Z51. Nothing major, but the differences are there.
Old 04-08-2018, 08:19 PM   #54
Pollock
LT4 M6
Pollock's Avatar
The rear of the car can be fixed with new craddle bushings. I did it to my 5th gen and it was a night and day improvement. The read end became solid and the shifty feeling was gone.
Have not messed with this car as its no where near as bad as the my old 5th gen was and changing out the bushings is a pain in the butt. However BMR makes a lockout kit I have my eye on they say helps almost as well as new bushings and so much easier to install.
Old 04-23-2018, 11:21 PM   #55
Bosse'sBoss
Bosse'sBoss's Avatar
Drives: '16 Camaro SS 6 spd manual transm.
Originally Posted by DFW1LE View Post
Also, a previous vette owner, and when I went shopping back in November 2016, I also test drove a GS to make sure I wasn't making a mistake. I found the 1LE to be every bit as competent, and being older was much easier getting in and out of, and also fit better in my rather tight garage.
The SS 1LE might be competent with the Z51 but not with the GS which is in another league.
'16 Camaro SS
Prior cars:
'14 Corvette C7 Stingray Z51
'14 Camaro ZL1 w/. Recaro seats
'11 Mustang GT 5.0 w. track package
'02 Porsche 911 Carrera
'05 Infiniti G35 coupe sport
Bosse'sBoss is offline   Reply With Quote
Old 04-23-2018, 11:30 PM   #56
TrackClub
TrackClub's Avatar
This may depend on GS trim and specifically tires.
I had to work hard for it 3 or 4 laps but eventually did pass my buddy in his brand new GS at Mosport (note his didnt come with cup2s).
