03-13-2018, 08:38 AM | #15 |
Drives: 2002 camaro ss Join Date: Mar 2018
Yes she is fast my nick name for her is tiger shark.
Is there either a camaro club or a LS club in winnipeg? When running in the garage she does not seem to be loading Up with fuel. That at least what my ears and nose say. |
03-15-2018, 02:11 AM | #16 |
Under a Peterbilt
Drives: Rogue, Durango and Camaro Join Date: Jul 2009
Ok where to start? First off, grammar goes along way. Next, LS6 blocks came in 10% of the 01-02 LS1 equipped Fbodies. Next the only heads GM put on from factory were the 241 heads on LS1 01-02 Fbodies. The LS6 intake manifold replaced the LS1 manifold for the 01-02 production. That SLP Blackwing intake Lid was an SLP option when the car was ordered at dealerships for the 01-02 production. With out a soundclip of your car idling nobody on here will know if you have a cam, but your car running too rich will not give you extra power.
Sold-2006 Pontiac GTO
M6 1 of 475 353rwhp 353rwtq Sold-2000 Camaro SS A4 Hardtop #867 of 8913 1 of 103 Bright Rally Red Hardtop SS A4 in 2000 2011 Camaro 2SS/RS M6 By Berger #11BC21 |
03-15-2018, 02:18 AM | #17 | |
Under a Peterbilt
With MAF cleaner, you can get it at any auto parts store. If this is true, you have either a deeper pan or your engine is running the truck filter for a 2500 with an LQ9, the filter is larger to hold more oil and prevent starvation.
M6 1 of 475 353rwhp 353rwtq Sold-2000 Camaro SS A4 Hardtop #867 of 8913 1 of 103 Bright Rally Red Hardtop SS A4 in 2000 2011 Camaro 2SS/RS M6 By Berger #11BC21 Last edited by King Nothing; 03-15-2018 at 02:29 PM. |
03-15-2018, 12:09 PM | #18 |
What mods did you do to your LS1
03-15-2018, 12:17 PM | #19 |
What i had verified is the harmonic balancer will not allow a magnet to stick to it
And also i tried to upload a video and the phone ( iPhone ) says invalid file |
03-15-2018, 12:18 PM | #20 |
I thank all you out there for the help
03-15-2018, 02:24 PM | #21 |
For my education how do u know it running rich? I would like to learn.
03-15-2018, 02:41 PM | #22 |
Under a Peterbilt
10 years ago I did Heads/Cam, did all the work in my buddies garage. My LQ4 is in the garage, cylinders are already bored .030 over, my 243 LS6 heads are in boxes next to it and my LS6 intake is in another box. My car is a 2000 so on the stock LS1 is the stock LS1 intake manifold. I still need to have the block cleans and order the internals for my 6.0 build.
03-15-2018, 05:18 PM | #23 |
Interesting
Good luck , what the bore of the lq4 block? |
03-15-2018, 07:44 PM | #24 |
I been told that the slp drive shaft was the strongest
On the market, is that true, and BTW way it a 4gen I am talking about. How many drive shafts were offered To camaro owners. My car appears to have a drive shaft The color of exhaust tubing . If it is aluminum is it a weak part ? Thanks |
03-16-2018, 01:31 AM | #25 | |
Under a Peterbilt
Crank is probably going to stay stock 3.62 and the cylinder bore will be 4.030
03-16-2018, 09:00 AM | #26 |
Thanks
03-17-2018, 11:54 AM | #27 |
Are you going to use forged components inside your engine?
What can are you thinking of using? |
03-19-2018, 02:31 PM | #28 |
Under a Peterbilt
Nope, engine is staying NA and it’s not going to be raced. The cam will probably be a 224/236 on a 116LSA.
