03-26-2019, 01:56 PM | #1 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Feb 2017
ZL1 A10 Fuse Pull + Cat Delete
I finally got around to the "51" fuse pull and secondary cat delete today. I have to say I finally have some exhaust sound in 9th and 10th gear (mostly thanks to the fuse pull). Before, I could feel the back-pressure of the closed valves when in auto mode when I slowly increased pressured on the gas pedal. It was completely silent until I hit 2K RPM. In manual mode, hitting the gas in 9th or 10th resulted in no exhaust sound whatsoever.
As for the secondary cat delete, I sense there's only a minor bump in sound, but only in higher RPMs. Hard to tell though. May be time to go with a Corsa Extreme axle-back to get the bump I need. |
03-26-2019, 02:21 PM | #2 |
AXLERODZL1
Drives: 2019 Riverside blue ZL1 Camaro Join Date: Dec 2018
Delete the primary cat.... that will definitely wake it up.
'19 ZL1 A10 Riverside Blue PDR/Nav/Sunroof
Kong ported blower/snout Roto-Fab Big gulp 103 TB Lingenfelter Lower Pulley(9.17) 1 7/8 ARH headers and Exhaust Meth injection(single nozzle) 733whp/788tq |
03-26-2019, 03:58 PM | #3 |
I thought about that, but then I'd break the warranty for sure after tuning.
04-04-2019, 08:20 AM | #4 |
Drives: 2019 ZL1 / Red Hot / A10 Join Date: Mar 2018
04-04-2019, 11:42 AM | #5 | |
Drives: 2018 ZL1 Join Date: Sep 2017
If you throw a rod and all you had was the 2nd cat delete....I would like to think most stealerships would still work with you but you do it after a tune....no way! |
