02-09-2019, 11:17 PM | #1 |
Grinding on 1-2, occasionally 3-4 under WOT
When I am pushing her hard, the trans grinds sometimes from 1-2 and rarely 2-3. Is this a sign of clutch starting to go? I know for certain I have the pedal pushed down. Once I had to press the clutch twice to get it into second.
416HP, 422TQ. Rotofab CAI, Dyno Tuned. ALP's and a V1. |
02-10-2019, 08:40 AM | #2 |
Apex Predator
Drives: 2010 2SS/RS M6 Rally Yellow Join Date: Jul 2013
This happens to me sometimes...I wonder if I need to bleed the clutch. Mine's a 2010 and it got a new trans in 2013 (snapped my output shaft like some other early cars have experienced)
2010 Camaro 2SS/RS - LS3/TR6060, Paid Off \o/
Beating physics into submission since 1991. |
02-10-2019, 09:21 PM | #3 |
How would bleeding it resolve this? I am increasingly concerned because I don't want to drive off somewhere far and lose the clutch. Problem is that I bought it used, so I have no idea when it was last replaced (if ever). I'm wondering if I should just preemptively replace it.
02-10-2019, 10:55 PM | #4 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
I would try bleeding your clutch / replacing the fluid and changing your transmission fluid and going from there. There are a lot of options for fluids that SS guys like to run.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
02-10-2019, 11:20 PM | #5 |
Clutch was bled in October 2018. Transmission fluid replaced in November 2018.
I have already tried the fluids
02-11-2019, 12:51 PM | #6 |
Hm. That's unfortunate. My next thought would be to upgrade to the Ideal Garage master cylinder for your clutch (which frankly I would do if you swap your clutch too). But it does sound like your clutch is dying.
Now that said to my knowledge if you aren't racing or anything it seems like the clutches in these cars don't just "go". It'll just keep getting worse. Both my stock and my previous twin disc clutch would drive "okay" at the end of their life but it was obvious they would slip under low rpm high load or just taking off and caused me to grind 2nd and 3rd maybe a half dozen times total.
02-11-2019, 03:35 PM | #7 | |
I can't find the master cylinder you mention.
02-11-2019, 04:46 PM | #8 |
I guess IdealG doesn't exist anymore. That is also unfortunate. But yeah, I definitely think you don't have to worry about it yet. Depending on how much you drive it could very well be this year though. Once you get uncomfortable with it, swap it.
02-13-2019, 06:53 PM | #9 |
Drives: 2012 camaro 45th 2ss/rs Centri SC Join Date: Nov 2016
you have a 14? You shouldn't be having those issues, as they were using the carbon fiber synchros by then. My suggestion is to make sure you have a remote reservoir for the clutch, bleed it again, and consider swapping in a stainless clutch line and master cylinder from tick...if that doesn't fix it then you're looking at a synchro job for the trans
Jeremy
-2012 Camaro SS 45th M6-Kraftwerks Supercharger -2003 Avalanche z71-6" on 35's. DD 290k miles -66 mustang fuel injected resto-mod |
02-17-2019, 07:11 AM | #10 |
Drives: 2015 Camaro 2SS/RS 1LE Join Date: Feb 2018
Its your synchros , im going thru the same issue with a 2015 1le . The Tremec6060 is know to have this problem. Swapped out fluid and changed clutch same issue. Ordering full carbon fiber rings soon !
2015 Camaro 2SS/RS 1LE - LSX376-B8, Eforce-1598 Supercharger, N20 Dual Stage kit , ARH Headers and CatBack , Willwood Big Brake Kit ,BMR subframe connectors, AFe Rear subframe bushing , AFe PFADT Tie rods and Trailing arms, and MRR z28 Replicas 20x10s and 20x11s - Toyo ST ii 285/30/20 - 315/30/20
02-17-2019, 11:45 AM | #11 |
White out- your car came from the factory with carbon fiber Synchros. e They shouldn't be worn. If they are you should be examining all your hydraulic components as something caused then to wear prematurely. All came with carbon Synchros.
Jeremy
02-17-2019, 01:05 PM | #12 | ||
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
Like in a truck without synchronization. If you can shift without gringing, is a problem with sanyronization. If the problem persists, is a problem in the clutch. |
